Question about GE (PSS26MSRSS) Side by Side Refrigerator
The water valve isnot letting enough water into the ice maker tray
  • 78 Answers
Low water pressure
Posted on Dec 11, 2009
Sub zero 245 stopped making ice, had service man out and he said wasn't getting enough water, and to replace cutoff valve and supply line and let thaw out. I did that and now have a water leak, but it is...
Most of the time the problem is the water valve that is electrically actuated by the ice maker controls. Remove the back panel and find the water valves and replace it. Many times sediment or wear and tear causes the valves to stop working properly or it becomes clogged with rust from the water pipes. If, the leak is at the ice maker then perhaps the problem is the water tubing alignment to the ice tray or the ice isn't dumping out of the tray, because the ice tray defrost element/ thermostat/ switch malfunction in the icemaker itself. It's difficult to find the cause without an experienced and competent refrigerator repair technician (such as myself) diagnosing the refrigerator onsite.
Feb 06, 2014 | Sub-Zero 245
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
Hi my auto ice maker is over filling the ice tray and spilling water into the ice holder so it will not come out as the spinning thing in the holder is frozen solid
The ice maker has a timer in it so that a solenoid valve will open only about 7 seconds or so and then close again letting just enough water to go into the tray. What you want to check is the solenoid at the back of the fridge around the bottom part where the water supply is connected. Lot of times it may have an internal leak were even if the valve is closed it is still leaking water into the hose that supply water to the tray. This would cause the tray to continually receive water overflowing it.
May 28, 2011 | Maytag MSD2756G Side by Side Refrigerator
Not making ice,checked optics ,good ,water valve coil tested good, no restrictionsbut i get no water in tray,also freezer temp is 8 degrees.
OK you mentioned the ice maker had no cubes or not making cubes, try filling tray with water from tap. Let freeze and if the ice drops into ice bin the ice maker is OK. Most times the ice maker thermostat is at fault (pt. 27 in photo) if not cycling. Read OHM's between both coils and they should be very near to same reading, if not replace water control valve=> 4389177 by applying first 120VAC to see if valve opens. If water goes into ice maker this way or OHMs between the two are nearly the same your Ice Maker=>2198597 Ice Maker Assembly may need replaced. If you would like to rebuild your Ice Maker here are the part Breakdown view=>
GS5SHAXN Ice Maker Replacement Parts
Let me know how your ice or water turns out, Thanks Sea Breeze
Feb 11, 2011 | Whirlpool GS5SHAXN Side by Side...
Ice maker will not make ice. No water in cube tray. It IS turned on.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Oct 31, 2009 | Refrigerators
My ice maker is letting too much water go into the ice tray so it freezes in a solid piece. Cubes do fall down but there is so much water it freezes into a solid block
The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Oct 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
ICE MAKER INOP
Check the water control valve on back and bottom of refrigerator. One side is for the dispenser and the other side is for the ice maker. When the ice maker begins a cycle the thermostat inside the ice maker begins to warm the bottom with a heating element to allow the ice to move freely and then dump into the container beside it. As the cycle reaches its final resting place a limit switch is pressed inside the ice maker to refill with water and start the process again. So if the water valve does not open and the tray remains empty and the ice maker will try to cycle again if the thermostat says that it is cold enough again. Check your model number again and I will try to get you some drawings. The number looks good but can't seem to pull it up. Let me know what you see and find. Try filling the tray with tap water and see if it will cycle after freezing. Thanks, Sea Breeze
May 20, 2009 | GE Refrigerators
My icemaker will not fill up the ice tray all the way
Your problem is either in the water inlet valve or in the ice maker it's self. It depends on what brand it is. if you can let me know age and brand and modle # I can help you futher.
Apr 01, 2009 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
73 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
