Question about Apple iMac G4 Desktop
APPLE IMAC G4 - TRYING TO INSTALL OS WITHOUT DISK EJECT BUTTON
I RECENTLY PURCHASED AN APPLE IMAC G4 WITHOUT AN OS. I OBTAINED TIGER OS, HOWEVER AM HAVING ISSUES GETTING DISCS IN THE UNIT. I PURCHASED AN APPLE KEYBOARD/MOUSE, HOWEVER THERE IS NO "DISC EJECT" BUTTON ON KEYBOARD. I CUT THE UNIT ON, AND A BLUE SCREEN COMES UP WITH A FOLDER SWITCHING TO A TWO PERSON SMALL LOGO ON MIDDLE OF THE SCREEN. I NEED HELP GETTING DISC EJECTED SO I CAN UPLOAD OS. ANY HELP IS GREATLY APPRECIATED.. I WILL OFFER $10 PAYPAL PAYMENT TO ANYONE SUCCESSFULLY ABLE TO GET ME THROUGH THIS. -BEST REGARDS- CORY
  • 2,841 Answers
Reastart the iMac and at the same time hold down the mouse left click button. If that does not work.
  1. Restart the computer.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (APPLE IMAC G4 - TRYING TO INSTALL OS WITHOUT DISK  - commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  4. At the prompt, type: eject cd
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
Posted on Dec 11, 2009
  • NOT ME Dec 11, 2009
    The above information is curtorsey> Apple
SOURCE:
How do I reset my imac 5.1 tiger to factory settings WITHOUT a disk
It depends on which OS you are running. OS 10.6 or lower requires a system disk. OS 10.7 and above has a recovery partition on the hard drive which allows you to format the hard drive and re-install a fresh copy of the OS. (To access the recovery partition, hold down CMD + R during start-up)
Nov 16, 2014 | Apple iMac Computers & Internet
How do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
IMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
If it only boots to a blue screen, try booting up in Safe Boot mode:
http://support.apple.com/kb/ht1455
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
http://support.apple.com/kb/ht2956
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
http://support.apple.com/kb/ht1710
May 18, 2010 | Apple iMac G4 Desktop
I mac g4 kernel panic cant boot from CD to format . got kernel panic after security update.No Driver for this platform
This message indicates that the CD you are attempting to boot from is a release of the Mac OS which is incompatible with this model of Macintosh. I would recommend a retail disk of Tiger or Panther for this vintage Mac.
Mar 06, 2010 | Apple iMac G4 Desktop
My iMac g4 1ghz wont boot
First hold down the right hand shift key down when you start, this does some housekeeping, The next step is if you have an install disk or tiger disk then start up from it by holding the "C" key down when starting and inserting the dvd, if this loads then go through the install menu, dont worry you do not need to actualy install just select language and then you get to a screen where you can select utilities from the menu bar, then select disk utility and repair permissions, after that do a repair disk then quit disk utility and change the startup disk back to the hard drive and restart, if for some reason you cannot repair the disk, this refers to the catalogs it uses to keep track , not the data itaelf, in that case you need a 3rd party utility like Disk warrior.
Feb 24, 2010 | Apple iMac G4 Desktop
Blueberry iMac with slot-loading CD rom drive will
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website
http://support.apple.com/kb/HT3007?viewlocale=en_US as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Nov 12, 2009 | Apple iMac G3, G4 USB Keyboard 9224078
Trouble shooting new os 10.4 tiger installation on mac pro
You sure you got the original gray label install discs for this computer? Sometimes people stick gray discs in with the computers and they are not specific for that model.  The Macbook Pro ships with Tiger 10.4.6
Borrow a black label Tiger retail disc from someone and install your OS that way.
Oct 27, 2009 | Apple MacBook Pro Laptop Computer with...
I without research Installed Windows XP on my Apple MacBook 13" White, 2.0 GHz, Intel Core2 Duo with 2Gb of RAM and 80GB HDD. It is the only NTFS partion, i.e clean install on the whole volume. Waz I...
If you did a clean install on the whole volume, you wiped your Tiger installation. The best bet is to install your preffered operating system first. When you do it, partition the drive into two of about equal size. Install the other OS into the other patition and have a menu to start the wanted OS when you turn on the computer. You will have to do some research on dual boot computers.
Jul 09, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
''imac g4 does not see dvd drive after Xferring files and setting
when booting in os x after the first boot chime immediately hold down keys <apple,option,o,f> all at the same time and allow computer to boot to open firmware once there type "reset-nvram" exactly like that but without quotation marks and press enter once it returns to command prompt type "reset-all"and press enter (you must have the "-" in between the commands) the computer should restart if not when the command prompt returns type "reboot" and hit enter ..... also you can check the drive status by going to "system profiler" in apple drop down menu--->about this mac-->more info or applications folder-->utilities folder--->system profiler then selct disk burning under hardware in the list on the left
Mar 18, 2009 | Apple iMac G4 Desktop
Photoshop on G4 imac
There have been some reported issues with PS7 on Mac Os 10.4.. first i would try repairing disk permissions.. if that doesn't work, you may need to do a fresh install, then download all the updates before you run the application for the first time.
Ciza
Oct 28, 2008 | Apple iMac G4 Desktop
Apple iMac G4 Desktop Logo
615 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
