Question about Refrigerators
My food wont get cold
The freezer wont freeze and my food doest get cold
  • Mark Egan May 11, 2010
    Please provide the model number for the refrigerator. Do you see frost accumulating at the back of the freezer section? Is any cooling taking place in the freezer section? Do you hear a fan running in the freezer section? Do you hear a fan running at the bottom back of the refrigerator (on the outside)?
  • Claire sansom Sep 01, 2013
    I have one the same, it is icing at back but then defrosts, there is a humming noise so is defo running. .
  • 78 Answers
Call sears
Posted on Dec 11, 2009
Kenmore elite bottom freezer refrigerator error code er rf
buy a new unit the least costly you can find .
Jul 17, 2015 | Kenmore Refrigerators
Freezer not freezing but still cold
you might have ice on the coil in the back of the freezer under the cover. move your food to a cooler. eat a lot of frozen food then unplug the freezer and leave the door open for a few days this will melt the ice hopefully with no effort on your part. then plug it back in and wait a few hours to see if it gets cold.
Sep 14, 2014 | Refrigerators
Why is my refrigerator is too cold food freezing ?
the door between the freezer and fridge that allows cold air to flow from the freezer to the fridge is likely stuck open,,,
Aug 30, 2014 | Whirlpool Refrigerators
Why wont my fridge stay cool?
MAKE SURE THE FAN IN THE FREEZER IS RUNNING THATS THE ONLY WAY THE REFRIGERATOR STAYS COLD DO YOU HAVE AN ICEMAKER IF YOU DO IS IT WORKING OR A DEFROST PROBLEM ANY ICE OR FROST BUILD UP IN THE FREEZER
IF YOU SEE IT ON THE WALLS ITS FULL BEHIND THE WALLS OF THE FREEZER
Jul 11, 2014 | Frigidaire Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My KitchenAid Subra fridge. it seems like the freezer is always producing cold air. It keeps the freezer so cold that it freezes the drain plug were the condensation is suppose to drain out of the freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 23, 2011 | KitchenAid Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
