Question about Dayton Gas Furnace Heater
I am having a problem with a dayton(3E229D) gas heater. It has a standalone pilot that is lit and stays lit. The problem is that the burners don't ignite. I turn the heat on at the thermostat the fan comes on after a delay but the burners are not kicking on. After reading a few DIY guides people suggested checking the thermostat by jumping the red and white wires together. Others the solved the problem by resetting the vent limit switch. Or is the gas valve bad andneeds replacing?
  • blkspy008 Dec 11, 2009
    locking out the valve?
    Problem Solver:
  • 19 Answers
If you can use a meter check for 24 volts at the valve when you call for heat. If you have 24 volts and no burners then the valve is bad, if you do not have 24 volts then another safety is locking out the valve
Posted on Dec 11, 2009
Pilot on furnace wont stay lit
Sounds like the thermocouple is shot
Nov 09, 2014 | Dayton Gas Furnace Heater
Pilot light on dayton gas heater model 3e469 wont stay lit
chech the flame sensor or thermocouple which ever it is equipt with. Sensors can be cleaned by lightly sanding them and therocoulpe's need to be replaced.
Oct 27, 2011 | Dayton Gas Furnace Heater
Dayton3e368a pilot lights but burners do not come on. Heat rod was replaced last year. Heater is in a greenhouse
Most heaters has a pilot proving sensor of one type or another, it will be in direct contact with the pilot flame to prove that the pilot is lit and then will allow for the main gas to the burners to open. If the proving device has failed then it needs replaced.
Oct 12, 2011 | Dayton Gas Furnace Heater
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
Pilot wont stay lit on waterheater. I replaced Thermocouple and that did not fix it. It will stay lit on vacation setting.
Most gas water heater problems can be fixed with yearly service that cleans burner and burner parts, checks gas pressure and bleeds air out of gas line, cleans air intake, and checks for venting and air intake problems.
Open following links for resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 27, 2011 | Water Heaters
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
How do I change the termocouple on an older Dayton furnace
Locate the gas valve,there will be three lines coming off the bottom and going into the burner compartment. The center one is the largest and is the main gas feed to burner. The one on right is usually silver and about 1/4 inch in diameter. It is the pilot feed line. The third is usually coppercolored ,this is the line for the thermocouple. You can trace thermocouple line down into burner comparment. The tip of the thermoucople usually slips into a friction fit mounted right in front of pilot burner.Slip old thermocouple out of holder and unscrew fitting from the bottom of gas valve. Install new thermocouple into pilot burner assembly,make sure thermocouple is fully seated and in direct line of pilot flame. screw fitting into bottom of gas valve. Set gas valve control to pilot,depress pilot button and light pilot. Hold pilot button down for about 2 mins.Tip of thermocouple should be cherry red. If it'snot try to reposition so thermocouple is more covered by pilot flame. Relese pilot button and if pilot stays on rotate gas valve control to on.Hope this helps you. Yhanks
Nov 20, 2010 | Dayton Gas Furnace Heater
Dayton 3e239e looking for operation manual
Normally you turn the gas valve to the pilot position, light the pilot, hold down the gas valve knob for 30-40 seconds and release. If the pilot will not stay lit replace the thermocouple. These are available ay Home Depot.
Ray
Dec 06, 2008 | Dayton (3E379) Heater
Dayton Gas Furnace Heater Logo
301 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
