Question about Sony KP-61V85 61" Rear Projection Television
Herringbone pattern service man checked my sony kp-61v85 because of a strange pattern in the picture. he said it was called a "herringbone pattern" and would be about 400-500 to fix. any suggestions for do it myself repair?
  • 2 more comments
  • bar2bad Jan 21, 2008
    He did not say what part it was, just that it would have to be taken in to be worked on. The pattern is there all the time on all channels and he hooked the tv up to different inputs and it was always there. He said he was hoping it was the tuner, but it wasn't.
  • jayf60 Aug 16, 2008
    everything text and pictures are shadowed.How can it be fixed?
  • Big Bad Dave Nov 25, 2008
    I have the same problem, except mine clearsup after it is on for a few minutes.
  • digiteyes May 11, 2010
    Did he say what the fault/part was that he needed to replace?
    Is the pattern there all the time, regardless of input selected eg: TV, DVD etc? Does it appear on all TV channels?
  • 110 Answers
Herringbone (and other patterns) can be caused my many faults, the obvious one the tech was looking for was a tuner/interference fault.
Another common cause is a faulty power supply.
Difficult to say without having the TV on the bench.
I'm a bit suspect about the $400 - $500 repair cost though.
Perhaps try another tech?
I doubt it's a DIY repair though.
Let's know how you get on.
Posted on Jan 22, 2008
Herringbone pattern at turn on clears as it warms up.
Does your TV show red, green and blue colors separated?
If the answer is yes, the problem is in the convergence circuit.
There are 2 integrated circuits (STK392-XXX) that need to be replaced by a qualified TV technician. The repair will cost around $150 or more.
Aug 13, 2014 | Toshiba 46H84 46" Rear Projection...
What are the differences between bamboo and solid wood floors?
Bamboo is much more environmentally friendly than solid wood as bamboo regenerates in time. Moreover, bamboo is harder than some solid woods such as red oak and black walnut.
Feb 06, 2013 | Building Materials
How to change the brightes
A fairly old model is listed here(KP-61v85) this answer is based on that model number:
If the set has not been serviced for a long time with set unplugged remove rear cover and locate (hard to miss) the three large black lens at top of chassis--clean the lens with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
If the lens are dusty/dirty they will diminish the brightness and clarity of the the picture---they are the light source for the picture in this set.
Apr 11, 2012 | Sony KP-61V85 61" Rear Projection...
I have a sony kp-61v85 color rear video projector and it has a red haze across the middle section of the screen like its out of focus. A tv repair man replaced 2 cv boxes and the picture got clearer and...
The tv have a problems is known as a convergence problems,it dead.The R,G,B colors lines mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resitors are dead.These parts on the tv convergence board,must be replaced to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Sony KP-61V85 61" Rear Projection...
What causes a herringbone pattern on L172WtProblem with the LG 17",ok on pc.problem entered 10 months there a fix now
Do you have another electrical device too close to your tv?
those patterns are caused by AC power leakage. You can move other devices i.e.sat box etc. further away from your tv to fix this.
Jul 14, 2010 | LG 17" L172WT Monitor
What causes a herringbone pattern on L172Wt television and composite input, but not PC input?
Your PC input is a secondary interfase, it does not go thru the IF and tuning sections.
It is possiable the if section has taken a surge and will need to be serviced.
Sep 04, 2009 | LG 17" L172WT Monitor
My sony tv Comes on some times but then some times does not
On most of your rear projections you got GUNS and if there out of allignment or overheat you will get this error and it will need to be serviced.
Apr 22, 2009 | Sony KP-61V85 61" Rear Projection...
Picture quality in cable mode only, watching dvd picture is
Herringbone pattern?
House stray AC 60hz signal is getting into the cable b/c the shield is not properly grounded. Call the cableguy
Mar 26, 2009 | Samsung 50 in. Plasma TV
Bad picture quality
You do not need to change the CRT's or lenses. The failure on this TV is the convergence ICs that became defective.
If you know how to solder, this should be an easy fix for you.
The IC markings are STK392-150 with locations IC1502, IC1506, mounted on a big heatsink(s).
If you want to change the complete assembly, you can check this link and ask them if they have the assembly where the STK392-150 ICs are mounted.
Good Luck.
Mar 26, 2008 | Sony KP-61V85 61" Rear Projection...
Sony KP-61V85 61" Rear Projection Television Logo
369 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
