Question about Motorola Mobility V750 Cellular Phone
Voice command - Motorola Mobility V750 Cellular Phone
No voice command
Try going to the settings menu and look for voice options. Usually there is a box that needs to be checked for the option to work.
Apr 13, 2014 | Garmin nuvi 2555LMT
Turn off voice command
Press the Voice Command key, and when prompted, say turn prompts off. To turn Voice Command on, press the Voice Command key and say turn prompts on.
I hope that you have found this information useful, and if I can be of further assistance, please let me know. Thank you for using fixya!
Jul 11, 2013 | Motorola Mobility MOTOKRZR K1 Cellular...
I need to de-activate voice commands in my mobile Nokia-5233 pls guide me
go settings > Phone > Voice command > Tools > Voice command >Option
Sep 23, 2011 | Nokia 5230 Cell Phone
How to activate voice command 3760t
Page 19 of your manual:
Activating Voice Command
Speak your wakeup phrase. The Voice Command menu appears.
Setting your Wakeup Phrase
The wakeup phrase is a word or phrase you can say to activate voice command. The default wakeup phrase is "Voice Command".
1. From main menu, touch Tools > Voice Command > Customize Phrase.
2. Enter a new wakeup phrase.
3. Touch "Done"
If this solves your posted problem, please come back and rate our answer. Thankyou.
Nov 05, 2010 | Garmin GPS
I have a garmin 3970t and the voice command does not work
The Garmin's not very good at recognising the default set phrase to initial voice command; i.e. "Voice Command". If you bring up the Tools menu, and touch Voice Command, it will tell you what phrase it's expecting to hear and provide a button to touch to customise it. The default, as I said, is "voice command", but for some reason, it thinks it's pronounced something like "Vwuss commont". Try it. It might work!
I changed my voice command phrase to "Voys Commarnd" (I'm English - it's how my accent would be written phonetically). It now works most of the time without a problem.
Aug 12, 2010 | Garmin GPS
Motorola K1 voice command problem
Hit your Voice command button on the right upper outside of phone, Hit Settings Hit 1 make sure Automatic is Checked, hit ok
Now Try Voice Command button again, and then hit your upper Right Softkey for Help on commands...
Jun 07, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Motokrzr k1m adding voice commands for voice dialing
You should be able to add a voice tag while editing the contact. You may also be able to simply activate voice dialing and press the voice dial button and say the name of the person and it will automatically dial for you. Try doing that.
Dec 18, 2008 | Motorola Mobility KRZR K1m Cellular Phone
Hi Ronnierat322,
Voice Commands:
The voice command hotkey is the "Home" key. To start using voice commands, press and hold the Home key until you hear a beep. Say "Help" and you should get a list of available commands and how to use them.
Media Player:
While watching a video, press the zero key to switch to full screen mode. Please see the link below for additional details on this:
http://www.fixya.com/support/t1104583-voice_command_button
I hope these help.
Please let us know how things go!
Thanks,
Jonathan
Oct 04, 2008 | T-Mobile Dash Smartphone
How do I use the voice command?
HI Con613,
Voice command is one of the feature of the mobile. It is important and if u understand it, it is very easy and useful to us.
Voice command is used to perform some sort of function (such as to open apps, camera, voice recorder, etc. and to call peoples) by giving voice command.
For it u need to go to voice command in tools in menu, then a list of apps appears. In it, u choose 1 apps, then it gives command to record voice. Record any voice of urs as command for it. When in standby mode or desktop, hold right soft key until voice command appears. Then give the same voice as recorded before to open the choosen apps.
Same process is to be applied for the apps.
For dialling people from voice command, u need to go to the person's contact. Go to options of it and add a voice as command for it. And same process is to be applied as to open the apps.
thank you
It is for mobile users.
If it is helpful for u, u can feedback me.
And i will help u later in other problems.
SAJAN
May 04, 2008 | GPS
Problem with voice commander htc P3300
its a common problem with voice commanders...as one cannot expect a low end processing device to process your voice with 100% accuracy...even the best of best voice processors that run on high end computers are about 80-90% accurate...I suggest you reinstall the voice commander and re-create the voice tags...
Apr 23, 2008 | HTC P3300 Smartphone
Motorola Mobility V750 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
