Question about Motorola Mobility V750 Cellular Phone
Voice command button can't be disabled - Motorola Mobility V750 Cellular Phone
Why am i getting low memory signal on my 2012 fiat 500?
Rolly: According to Fiat500USAforum.com: "What is causing your problem is the Ecodrive program. You can disable this using the Voice Response system I think the command is Ecodrive disable...but you might want to check the owners manual. I used the system with a thumbdrive, but lost interest and turned it off using the VR button on the steering wheel and voice commands. "
May 25, 2015 | 2012 Fiat 500
Hi, am using htc touch, wenevr i connect my headphones,which ever is the last call ,.it gets automically dialled.this is because of voice commander... PLS let me know how to disable this voice...
Hi, you can remove the voice command by using the manual for instruction. You can download the manual from the below link:
member.america.htc.com/download/web_materials/Manual/HTC_Touch_Viva/Opal_HTC_English_UM_1013.pdf.
hope it helped.
Oct 13, 2010 | HTC Touch Viva Cell Phone
How to disable voice command in nokia 5230?
please tell me how can i disable voice command in nokia 5230
Oct 08, 2010 | Nokia 5230 Cell Phone
How do I turn off voice my on virgin mobile phones
I'm unsure if you are speaking of voice recognition or voice services. The "call options" menu will customize settings.
To remove voice tags/commands from the phone select: menu>settings>call options>erase voice dial>yes.
To disable voice answer select: Menu>settings>call options>voice answer>disable.
To utilize only messaging services you need to contact Virgin Mobile, 1-888-322-1122, about text and data only plans.
Aug 07, 2010 | Kyocera wild card Cellular Phone
Is there a way to disable the voice recognition button on my Samsung intensity??? Whenever I go to slide it, I hit the button, and my phone talks, even when i hav the volume on vibrate only.
I have the same problem with my Intensity every time I keep it in my pocket. Unfortunately, you can't disable the voice recognition function completely, but you can make it more managable.
You can get rid of the voice that says "Please say a command" when you hit the voice recognition button, and instead make it just a single tone by following these steps:
- Hit the voice recognition button on the side of the phone
- Press the right option button to go to the Settings
- Go to #5, Prompts
- Select Mode
- Select Tones Only (the last option)
- Hit OK
You can also reduce the volume by changing the output from the speakerphone to the ear piece, to make it quieter. Go to the Prompts menu like you did above, and select #2, Audio playback. Set it to "earpiece" and hit OK.
Now, when you accidentally hit that button, the phone will just emit a short tone that you probably won't even hear. Hope that helps!
Jun 07, 2010 | Samsung SCH-U450 Cell Phone
How do you turn the voice command NUANCE off?
Go to MENU, SETTINGS AND TOOLS, SOUNDS SETTINGS, READOUT, then select FLIP OPEN AND TALK, turn it off.
Oct 02, 2009 | Samsung Smooth SCH-u350 Cell Phone
Motorola K1 voice command problem
Hit your Voice command button on the right upper outside of phone, Hit Settings Hit 1 make sure Automatic is Checked, hit ok
Now Try Voice Command button again, and then hit your upper Right Softkey for Help on commands...
Jun 07, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Turn off voice command in bias
I'm presuming you mean ASUS BIOS? whem you start your PC press and tap (or maybe hold) the F6 key, it should bring you into your BIOS etup, and normally the switch will be under the integrated tab, either disable the voice command if it is there.. otherwise check all the tabs (ensure that you scroll from top to bottom elseways try to contact the manufacturer and get their direction (OR check your users guide)
May 15, 2009 | ASUS Computers & Internet
Voice Command Problem
Hi sherri you are sure the connection the rear Audio/input is in the right location and the menu should have a selection under the menu/title that is a mute function
Sep 07, 2008 | Kenwood DNX5120 DVD Navigation System GPS...
Motorola Mobility V750 Cellular Phone Logo
91 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
