Question about Sony Televison & Video
Buzzing noise from Sony Bravia 40V5500
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} A couple of months ago I bought a Sony Bravia 40V5500 and I soon noticed an annoying buzz coming from whatever is behind the top middle vent. Decided to get a replacement but this one has the same problem so I thought it was normal for this model so decided to try and see if it would calm down.
However, it’s now driving me crazy as every scene with fairly quiet sound in a game/movie the noise can be heard even with the volume a 20-30. I have noticed the buzz is loudest when the screen is black and quietest when white, a mix of colour makes it kind of pulsate. I have tried changing every setting but nothing makes a difference and a Sony Bravia 40S2510 I have does not make a sound anything like this. The only noticeable time the sound lowers is when I switch to the PC input with nothing connected, no idea why.
What could be causing this and is there an easy fix.
The Marv
  • 72 Answers
SOURCE: Strange buzzing noise
Sounds like a bad filter cap in the power supply.when you change dimmer switch the buzz changes slightly because of a different power sraw on the power supply. If you are not versed in electronic repair. Get an Estimate. Or if unit is old get yourself a new one. Good Luck
Posted on Jan 03, 2007
lukster
  • 217 Answers
SOURCE: Buzzing sound coming from TV
Sounds like a power supply, could be a large capacitor or a large transformer making the noise
Posted on Apr 16, 2007
SOURCE: No picture and only buzzing sound coming from plasma with cracked screen
sounds like you may have a high voltage arc and / or leak . better to let a manufacturers qualified technician have a look at it this time . ask for an estimate after diagnosis and before repairs are made. factor age plus repair cost v/s a replacement tv . also in the area where i live most in shop repair estimates are cheap or even free . field repair estimates are definitely not . all tv parts can be replaced but, screen replacements can get expensive . barring neglect , abuse or a significant power surge you should not be having these problems on a tv so new. double check your warranty. most electronics come with 1 year on parts ,90 days on service. some warranty limitations are not allowed in certain states. also contact the manufacturer . in my expierence some of the better companies have honored an expired warranty partlialy and sometimes even fully on a relatively new product . after all they do have reputation to lose or keep . just be courteous and if your lucky they will be too. but if all else fails, i personaly prefer lcd flatscreen . oh , about the screen crack , clean and position your tv according to the owners manual . some of todays televison components are even more thermaly and chemicaly sensitive than ever . ie; window cleaner can whiten or even crack certain types plastics. finaly if you are not using a good surge protector now may be the time.
good luck
Posted on Feb 07, 2008
SOURCE: Loewe Articos 55 HDTV loud buzzing noise
sorry cant solve it ,i called all the loewe service agents and they all said the same thing, put up with it. a new engine/colour wheel cost around $2500,
Posted on Sep 23, 2008
SOURCE: TV buzzing when showing whites and bright colours
Where is the sound coming from, the television or are you running some kind of audio system? What cablles are you using (eg. HDMI, Component)? I can help you a little more by knowing these things.
Posted on Oct 16, 2008
40 inch sony bravia making buzzing noises....any suggestions
There are 2 small 1.5" fans that are located on the top right and left sides of the screen. These fans are of the non ball bearing type, so the bearings may be wearing out. You can either replace the fan or add a couple drops of oil to it. Remove the label on the back of the fan and put the oil there, it should quiet down. This will work for a while but eventually the fan will need to be replaced.
Good Luck!
Rich Lilja
Feb 28, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Service engine soon indicator on and a buzzing/whining noise.
i recommend that you take it into auto-zone or a car shop asap. from what you have described the ticking as, it sounds like a bottom knock. as for the whine i don't know.
May 14, 2010 | 2005 Nissan Xterra
Turtle Beach x1's make an annoying beeping noise
If you're using the Play n Charge kit, then you might be hearing some buzz/whine through the USB power. Use the X1 without the Play n Charge. Does that help?
If you unplug the chat-controller cable from the X1 volume control box, can you now hear shots and explosions without the annoying beeping/buzzing noise? If so, then you may have a bad chat-controller cable, and you should have it replaced.
Mar 05, 2010 | Voyetra Turtle Beach Ear Force X1 Headset
Buzzing sound on samsung
it sounds that u have a color wheel problem my friend
Jan 19, 2010 | Samsung DLP HL-P5663W 56" TV
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Buzzing
Mine has the buzzing. I even created this current one out of 2 damaged ones, the original internals did it as do the internals I took out the "new" one I got (it had a smashed screen). I noticed it stops completely when muted, but not when the volume is on 0. It also gets louder when the contrast is higher (just flick between the preset PICTURE MODE's). I think it's something to do with the internal speaker cables perhaps running too close to the display circuit or whatever (Im not sure what causes it, its normally electrical interferance being picked up by an unshielded cable). I'll no doubt get hacked off and reopen it soon to look about. I'll post back when I do, may be a few months though!
Feb 25, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Noise from the right side of thr fridge
I would suspect something has come loose, like a panel screw somewhere. When the refrigerator turns on its cooling system, it may be causing the rattling, due to vibration of whatever has come loose.
Jul 11, 2008 | Samsung RS2630SH Side by Side Refrigerator
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Buzzing noise
Fly back transformer will cause a buzzing sound like this. Really up to you how bad it bothers you it can be fixed but it will cost a couple hundred dollars. If you can solder you can put it in yourself but the flyyback will still cost a little bit of money.
Josh
Feb 28, 2008 | RCA F36650 36" TV
Televison & Video Logo
782 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
