Question about Maytag Neptune MDG5500AW Gas Dryer
I have a clunking noise when the drying cycle is running
I found a screw stuck between the dryer barrel where it spins around. I jiggeled the barrel enough so the screw fell out and problem solved.
Posted on Dec 12, 2009
My chevy 2500 clunks only when driving in 4 wheel drive
May want to look at the front axles. If the boots are torn and the joints are dry, the axle is causing the clunking noise. Also,check the transfer case fluid level,low fluid level can cause the noise due to dry or damaged gears.
Mar 05, 2015 | Cars & Trucks
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Intermittent high-pitched noise during drying cycle
It is probably the drum bearing going bad and yes it is okay to use but will probably sart clunking when it wheres out all the way.
Mar 11, 2010 | Dryers
Clunking noises when cycling off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Jan 05, 2010 | Refrigerators
Kichenaid kawe570bal0 agitator clunks
there is a gear, pop the top cap off the agitor, the gear is in there, near the top might need to be replaced, sears has most parts for most machines
Oct 03, 2009 | KitchenAid KAWS850L Top Load Washer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
128 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
