Question about Garden
It will run but stop, then difficult to restart.
I have problem starting it, then it run for while then stop, and it difficult to restart. I have run it in mid-throttle not full throttle.
  • 437 Answers
Sounds like the ignition module is opening up when it gets out. you will need to replace it.
Posted on Dec 17, 2009
HOW CAN I STOP MY 1986 MORGAN 4 X 4 MISFIRING AND DIFFICULT TO RESTART WHEN HOT
Plugs, plug wires, distributor cap, rotor button basic tune up is where to start.
Jul 19, 2016 | Morgan Cars & Trucks
Tip
How to stop the Annoying Windows Automatic Updates Restart Dialog box
YOU CAN TRY THE FOLLOWING STEPS TO DISABLE AUTOMATIC UPDATE SERVICE.
  • GO TO START-RUN
  • THEN TYPE CMD CLICK OK
  • IN THE COMMAND LINE TYPE THE FOLLOWING COMMAND AND HIT ENTER
  • "NET STOP WUAUSERV" COMMAND (LESS QUOTES) TO STOP IT
  • AND "NET START WUAUSERV" TO START IT.
  • WINDOWS XP USERS HAVE TURNED ON AUTOMATIC WINDOWS UPDATE WILL HAVE ABSOLUTELY NO PROBLEM
  • RECOGNIZING THE "RESTART NOW, RESTART LATER"
  • THE EASIEST WAY TO STOP THIS ANNOYING WINDOW IS TO START WINDOWS COMMAND PROMPT (START -> RUN -> CMD)
  • AND TYPE THE FOLLOWING COMMAND:
  • SC STOP WUAUSERV
  • AND THEN HIT ENTER.
  • THE RESTART WINDOW WILL DISAPPEAR IMMEDIATELY INCLUDING THE ICON IN THE SYSTEM TRAY.
on Feb 19, 2011 | Computers & Internet
I have a Poulon 445 tree trimmer that runs okay until it stops. I replaced the carburetor new from Stihl dealer. Still floods and won't restart if trigger is released to idle machine.
Sounds like an air leak somewhere. Usually in the crankshaft seals. It runs fine wide open but won't idle and is difficult to start
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Dec 29, 2015 | Stihl Garden
Yardman blower jut quit running like it was out of gas, restarted then did the same thing, now its difficult to pull the cord to strt
I'll guess and say that the carb flooded the engine and you have hydro lock.Pull the sparkie and clear the extra fuel.
The carb is at fault,IMO.
if the needle get a little dirt in there it will hold the float open and flood the motor.
Dirt.
Nov 16, 2012 | Yard Man Mulchinator QuickShift BlowerVac...
I changed cam phasers and runs great when cold. When it warms up it stalls at stop lights and gets difficult to restart
have vechicle code scanned bad engine coolant temperature sensor will cause vechicle to stall out and hard to crank when cold.
Sep 11, 2012 | 2004 Ford F150
HARD TO START. WILL ONLY RUN ABOUT 20 SECONDS.
Your carburetor needs cleaned. Disassemble and spray with carb. cleaner. TIP: Use a Den Tek Brush, (used for cleaning between teeth),to clean small portals in carb. check the small screen in carb. for debris. Reassemble and start. If it still doesn't run properly, buy a carb. kit and replace the small screen, needle valve, gasket(s), and diaphram. this should definitely do it.
Jim
Jun 04, 2009 | Garden
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
