Question about Linksys Wireless-G WRT54G Router
Linksys Wireless WRT54G vs. WET54G
I apologize for the long post but I want to give you the necessary details.I'm using WMP11 (media sharing enabled) on my PC and want to share video, music and pictures from my PC with my HD DVR #HR21 and Pioneer plasma TV. The PC is running WinXP Professional + SP2. Here is the situation: The PC is in a different room than the HD DVR & Plasma TV. The cable modem and wireless router connected to it is in a 3rd different room of my house. My Setup:-------------Internet via Comcast Cable Modem, which is connected to a Linksys WRT54G wireless router via Cat5 cable. As stated above the cable modem/router, HD DVR/plasma TV and PC are in 3 separate rooms. The PC running WMP11 connects to the Internet/home network via its internal wireless PCI cardSuffice it to say I do not have a hard wire cable modem in the rooms where the PC and HD DVR/Plasma TV are located.The HD DVR is connected to the plasma TV via HDMI cableNow I want to wirelessly connect the HD DVR to my PC running WMP11, which brings me to my question:I realize I can connect the HD DVR to a Linksys WET54G wireless G ethernet bridge or a Linksys wireless gaming adapter to achieve the desired connectivity, but can I wirelessly connect the HD DVR to the 1st Linksys router, mentioned above using a 2nd Linksys WRT54G wireless router functioning as a client bridge instead without creating configuration issues between the 2 routers? Is there any 3rd party software (dd-wrt?) that I will also have to run for this scenario to work? The advantage of going with the 2nd Linksys router instead of the wireless bridge is that it is less expensive and the router provides additional ethernet ports for use with any additional ethernet-equipped components; e.g. HD DVR + XBox.I am not married to using a 2nd router, but I would like to have the option of using something that will provide me with additional ethernet ports for other components. Or am I relegated to purchasing extra wireless bridges for each ethernet-equipped component I want to have in the media area?Not sure if I can use the 2nd ethernet port on the back of the HD DVR to act as a pass-through for Internet/home network access for a 2nd component that requires Internet access? If I can that will take care of connecting the HD DVR and a 2nd component to the Internet & home network just using a single wireless bridge such as the WET54G. But what would I do if I have a 3rd component that needs Internet/network access? Please let me know if what I am suggesting will work and what steps I would need to take in terms of any additional software or set-up process. I don't want to make any purchase before I hear from the experts.Thanks in advance.
  • michaelduke Jan 21, 2008
    I checked out the dd-wrt and saw the suitable routers that would support the dd-wrt software. I did not see the Linksys WRT54G listed, but did see the WRT54GS. Major difference between the two of them is that the GS model has SpeedBooster installed on it, which helps transmission speed. I am up for trying out the GS but I have some questions:
    All of my PCs in my secure home network are equipped with wireless G adapters, etc., not GS. If I connect a GS device in this environment will that cause any issues within the network? Specifically, the security protocols for all of the wireless G devices are WPA encryption, which is how I set up our home network security. The GS router only has WPA2 security protocol, which does not match what I already have. It is my understanding that if the security protocols of all the hardware in my setup are not exactly the same the home network will not function properly.
    Any suggestions?
    Thanks in advance.
  • Anonymous Mar 30, 2014
    How do I setup the client bridge to connect tonmy house router through ddwrt
Using Tomato firmware, (google it) I have used a WRT54GL to extend the wireless range of another WRT54 router. Use Tomato to create a WDS - Wireless Distribution System. I successfully connected two computers wired to the second router that is connected wirelessly to the first router. This worked flawlessly.
I wanted to watch my sat tv in the computer room and didn't want to buy another TV/Sat receiver, so I bought a Slingbox Solo. They recommended the WET54 for a wireless bridge. I was just about to buy it when I thought, why would I do that. I got a third WRT54G for 1/2 the price of the WET, put Tomato firmware on it and added it to my WDS from my other two routers. I wired the slingbox to it and it streams my satellite TV fine. As for the previous comment, I stream movies from my NAS to two AppleTV's wirelessly with no problems at all. Get the WRT54GL and don't waste your money on the bridge. The bridge essentially connects one wired peripheral to your network. The WRT54GL extends your wireless network and connects 4 more wired peripherals at higher throughput and less money.
Cheers!
Posted on May 03, 2009
    Scholar:
  • 112 Answers
For what it is worth, I fhave found streaming video does not function well using a wireless connection. The options of multipale routers will work as long as you configure them as to not have conflicting IP address assignment's via DHCP, and the routers do not have matching IP address's. Never fear all is possible with paticence. BPCS
Posted on Jan 20, 2008
2 Suggested Answers
  • 15 Answers
SOURCE: 3rd party firmware broke my router!
did you check whether you have downloaded the correct firmware for your linksys???
Posted on Dec 04, 2007
I want to connect a Scientific-Atlanta WebSTAR 2000 series Cable Modem to a Linksys Wireless-G WRT54G wireless router but the linksys doesnt detect the modem and the computer wont let the setup program for...
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting Devices Together
iii. Checking the Router's LEDs
iv. Configuring a Linksys Router for a Cable Internet Connection
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G WRT54G Router
So I have a little problem. I'm trying to find out how to connect 2 wireless routers together from across the house. The internet side is connected to a Linksys wireless router (WRT54G). This is located in...
you need a wireless ethernet bridge(like wet54g/wet610n) which will grab signals wirelessly from u're primary router wrt54g,& then a ethernet cable from wireless bridge will be connected to one of the lan port of u'rs netgear router(otherwise u will not be able to do file & printer sharing between 2 routers)Remember,the ip address of all 3 devices shold be of same class.
Jan 02, 2010 | NetGear WGT624 Wireless Router
I can not get my Linksys WRT54G router to pair up with a new computer with Windows 7.
Linksys provides detailed steps for this issue. Please use link below for instructions for Windows 7:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=5451
Please verify a MAC or IP Filter has not been enabled on Router. This will not allow any additional computers to connect to router.
Good luck
Dec 30, 2009 | Linksys Wireless-G WRT54G Router
I lost my CD Installer for wireless-G 2.4 Ghz
You can find the software that was loaded on the CD at the linksys website.
http://www.linksysbycisco.com/US/en/support/WET54G/download
Dec 29, 2009 | Linksys WET54G 2.4 GHz 802.11g Wireless-G...
No print sharing. Existing but lder Belkin router has no problems, but WRT54g-TM will not print share. Have a Netgear switch box as well, can I integrate the two or even all three to solve print share...
If you are using a belkin router, wrt54g-tm and netgear switch box. Basically they won share the printing. you need a wireless print server..try the linksys WPS54GU2
Jul 28, 2009 | Linksys WRT54G-TM Wireless Router
I want to security enable my wireless internet
What you are asking about is called Wep security and is available in your router control panel ("http://" whatever your router is set to) then go to wireless>security and setup a Wep key. You can also go to this web page for more info:
http://www.linksysbycisco.com/US/en/support/WRT54G
Good Luck...
Tim
Mar 26, 2009 | Linksys WRT54G Wireless-G Broadband Router...
Does not operate
Be sure you can browse internet using wired LAN
Connect to Router using LAN cable and configure it.
Enable Radio and set security protocol.compatible with your PC wlan card.
Jan 09, 2009 | Linksys Wireless-G WET54G 802.11g/b...
I can't access my router through the URL.
Linksys will not allow you to access admin on your router on a wireless adaptor by default. You will have to enable it or use a wired connection.
Is file sharing enabled on the computer you are trying to get the media files from?
Aug 21, 2008 | Linksys Wireless-G WRT54G Router
Unable to get my WET54G up and running
Make sure that you routers IP range is setup to handle the IP address of your PC.
Feb 02, 2008 | Linksys Wireless-G WET54G 802.11g/b...
Linksys Wireless-G WRT54G Router Logo
1,211 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
