Question about Clio Designs 3250
Locating water bottle under bonet of clioin order to fill washers. model year 2000
    Problem Solver:
  • 5 Answers
Right hand side of the bonnet (Battery side) on the scuttle panel
Posted on Jan 08, 2010
Check water level
Under hood there are 2 white plastic bottles. One is window washer fill and the other is the radiator overflow/fill. Look on side of bottle. It will have the water level marked on it/
Nov 03, 2013 | Chevrolet Aveo Cars & Trucks
I put screen wash in my renault clio coolant bottle
its ok...its water based,but if you want to remove it,under the radiator there should be a purge valve remove it let the liquid exit,replace the valve fill the radiator with coolant,start the engine,turn heater to max,turn ac to max on heat,allow it to reach normal running temp and refill if necessary
Oct 19, 2013 | 2008 Smart fortwo
Rear windshield washer pump
Mostly in rear side panel with the bottle to fill. Some models have two pumps in front under bonnet at bottle base
Dec 02, 2012 | Nissan Cars & Trucks
I cant locate the water bottle to fill up the squirters. also does a 97 clio van have power steering?
squirters ---- belly laugh from this end ,look under the plastic grill passenger side ,it lifts up and the squirter reserve is under it ...... as for power steering some do and some dont depends on the build spec of the vehicle as it comes down the assembly line .
Apr 28, 2011 | Renault Le Car Cars & Trucks
Windscreen Washer Motor not functioning. What shall I do ??
Hi
Are you sure it is not just frozen? if it is not then got to the water bottle and you will be able to see the black motor with the wires coming out, these things tend to last a long time and most often if they are not working it is a loose wire or siezed up with the cold.
Do you know the location of the water bottle? if not get back to me and I can send you a picture. Also I am assuming this is a Renault Clio??
Regards
Dan
Dec 28, 2010 | 2000 Renault 181
I have got a kia sportage and the front washers are not working i think it might be the washer pump not working where can i find it on the car
The washer pump is bolted onto the under neat of the water bottle(bottle where you fill the water for the washers),, remove the bottle and you will see a small cylinderical device mounted into it,, with 2 wires attached,, pull it ount and the remove the wire connector,, Thats your pump..
Jul 05, 2010 | 1995 Kia Sportage
Rattling noise from my clio engine?
Was the car using much coolant before you forgot to replace the coolant bottle cap?
The clinking noise you describe - that may be 'pinking'.. a noise caused by an incorrect air/fuel mix .. and also a symptom of a blown head gasket. Another symptom of a blown head gasket is white smoke (steam...) from the exhaust.
First, check your engine oil on the dipstick. If the oil is a creamy grey colour this indicates a blown head gasket. The creamy grey colour is caused by coolant finding its way into the oil system.
Fill up your coolant bottle with coolant. Leave the cap off, and start the engine and let it tick over for 10 minutes. As the engine warms up air will escape from the coolant level - keep topping up as necessary.
Keep your eye open for extreme bubbling in the coolant bottle - violent bubbling in the coolant bottle is caused by exhaust gases finding their way into the cooling system via a defective head gasket.
If there's no violent bubbling, replace the coolant bottle cap when the engine has ticked over for a few minutes..
... and then begin to look for leaks as the engine ticks over. Look under the car to see if there's any falling fluid. Check around the radiator and the hoses. Check that the coolant bottle itself isn't leaking.
You say your car isn't overheating - that's a positive. One symptom of a blown head gasket is overheating.
However, your coolant is going somewhere and you should try and find out where ... If it isn't a leak from somewhere, it may well be the head gasket.
Prices? To have a cylinder head gasket fixed costs around £500 - £1000 British pounds. A coolant bottle costs around £30 (look on Ebay)
If the head gasket is leaking/defective you can try a modern sealant/repair, which I am told are now quite good. Have a look on Ebay:
3 229results for cylinder head sealant
Mar 15, 2017 | 2000 Renault 181
Maytag washing machine model PAV3360AWW won't stop water on selected water level.
It sound like you have a bad float switch and it is not reading the water level right.If it is filling and wont stop then a possible new water valve is in order:) The float switch is locatted under the top panel of washer
Dec 30, 2008 | Maytag PAV2300 Top Load Washer
GE top load will fill with water, not spin, agitate, empty water
very familiar with this look under machine if black dust found it has a broken motor coupler, very easy to change
Dec 22, 2008 | GE WDSR2080D Top Load Washer
Clio Designs 3250 Logo
243 people viewed this question
Top Clio Designs Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Clio Designs Health and Beauty Expert? Answer questions, earn points and help others
