Question about Hotpoint FFA80 Bottom Freezer Refrigerator
Hotpoint Mistral Fridge freezer no Power Issue
Hi I have Hotpoint Mistral Fridge freezer model number FF80 and it's stop working -- no power. I've checked fuse and power socket all ok.
Can anyone advise what the issue could be pls.
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Dec 11, 2009
Hotpoint Mistral Fridge Freezer, freezer working fine at -22 degrees, however, fridge has stopped working and is on +19 degrees. Had an E8 error message a few weeks ago which was quick fixed with a turn on...
Evaporator thermistor is on the radiator located at the back of the fridge. Older fridges had a big on aircooled along the entire back of the fridge whilst the newer ones have it under the fridge with a fan cooling it. 90% of the time the fan gives up causing this type of issue.
Jun 28, 2017 | Refrigerators
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
HOTPOINT MISTRAL plus 8596 fridge E2 code
Go to this site: http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=35
Type "Mistral Thermistor" into the search and help will be availible. You have a very common problem which is an easy fix in most cases. Good luck.
Mar 13, 2010 | Hotpoint Refrigerators
Hi i have a hotpoint mistral plus fridge freezer, the freezer working fine however the fridge not getting cold, i have checked in back and the fan not working, have checked the fuse that is fine. 1) Does...
hi is this the frost free version ??? if it is which i think it is it could be a fault with temp module{frost free have electronic modules to control the system rather than a old fashioned bog standard thermostat inside the fridge} the fans should be controlled by the module in case of frost free models it could be the module which is playing up
Jul 23, 2009 | Refrigerators
The fridge and freezer is not chilled
power to the house was shut off for repairs, when power was restored the freezer part of the fridge stopped working but the compressor still runs.
Mar 19, 2009 | Hotpoint HSS25GFP Side by Side...
I have a 10 year old hotpoint mistral plus frost free fridge freezer whic keeps coming up with EA as an error message in the display screen. We have turned the appliance on and off which sometimes solves...
thanks for the question yes it very well could i would pull fridge away from the wall and clean the condenser if dirty makes all the difference especially in that heat thanks the appliance doc
Sep 24, 2008 | Hotpoint Refrigerators
My hotpoint mistral fridge/freezer is freezing very will, but ther fridge is not cooling. What could be wrong?
Hi. I had the same problem (funnily just as my warranty had run out) hotpoint wanted about £90 plus parts for a call out. You need to replace the Yellow thermistor in the freezer compartment (quite easy with a cross screwdriver and thin fingers). I got mine from Uk White Goods for about £20 they give advice too. Solved it instantly. Thanks HOTPOINT, wont be spending £600 with you again. Good Luck.
Jun 20, 2008 | Refrigerators
I have a Hotpoint Mistral frost free fridge freezer model FF72P (according to the sales invoice). The freezer is working fine but the fridge is not cooling. The fan that circulates the air is working...
It is possibly the fan hitting any overformed ice.
defrosting by shutting it off overnight would be the best to do first.
Or at least shut it off for a few hours.
Mar 05, 2008 | Refrigerators
Condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Sep 25, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint FFA80 Bottom Freezer Refrigerator Logo
554 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
