Question about Dryers
Kenmore series 80 wont spin without helping to spin by hand.
The machine alway made a load klunk when shifting to spin.Now you have to catch the machine right when its ready to spin and help turn it by hand to get started.
  • 744 Answers
This sounds like the drive belt is worn out and slipping. You'll need to turn off the power and water to the machine, pull it away from the wall, remove the back panel and change the belt. It's under the main drum assembly and visible. This isn't the easiest thing to do, so if you are not compfortable with this type of work, you may want to consider calling for service.
Posted on Dec 11, 2009
Our 80 series kenmore became unbalanced with a loud klunk. The metal shell came off the machine. It will not spin but will work on wash?
You may be able to find the problem by looking at the illustrated parts breakdown.
Sears maintains such drawing on nearly all of the brand names they sell and many more:
http://www.searspartsdirect.com/partsdirect/
Enter your model number in the provided search window there.
There are also links on how to find the model number if you have trouble locating it.
Jul 02, 2014 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model 22832100 does not always spin fast enougf
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 03, 2010 | Kenmore Washing Machines
Kenmore 80 series washing machine model stopped spinning
Check this out acc8ce4.jpgmight be a partially defective coupling or lid switch. More HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 21, 2010 | Kenmore Washing Machines
When in spin made loud klunking and screaching noise. now will not work in spin cycle without making loud klunking noise
Pull off the bottom panel, (three 1/4" screws along bottom). Check for chunks of concrete hanging down, or in the bottom pan. I have seen the lower front counter-weights on the HE2 break off several times. If not, reach in and give the basket a hard spin by hand, if you hear clunking or grinding, or the basket feels loose, you have a bad basket brace (usually caused by slop in the rear bearing). You would need to replace the rear shell (comes with a pre-installed bearing) and the basket. Depending on age, these parts may be in warranty, check your manual.
Apr 20, 2009 | Kenmore HE2 Plus Front Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
