Question about Smeg Dishwashers
There is a problem
There is a "sun"sybol on display and the dish washer doesnt start
  • tonypmcgrory Dec 12, 2009
    hi there its tony again its a smeg itegrated dishwasher model dw1614
  • Smeg Master
  • 19,396 Answers
Hi Tony.
We would need to know make and model of your dishwasher, so that we can help you.
Thanks.
Posted on Dec 11, 2009
MDB 8750 Dish Washer Doesn't start the Wash Cycle.
Yes this can be a touch pad failure that may need to be replace again , because with this type of device usually the touch pad is easy to get bad...
Good luck........
Aug 19, 2008 | Maytag Dishwashers
I have a 501 ht moyer diebel undercounter dish washer that doesnt drain all the way
Could be a clogged drain line, a failing pump or even the dishwasher not level
Jan 16, 2013 | Dishwashers
Dish washer won't turn on when start button is pressed
Check your door switch. My dish washer would not work a couple of months ago, tore apart and messed with door switch and it has worked every since.
Dec 22, 2011 | Washing Machines
Food particles remain in the dishwasher and on dishes
Hello, if someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
If you recently installed a garbage disposal there is a knock out that many people forget to do on the disposal that, if you don't knock out will cause some of the risidual food from the disposal to seep back into the dishwasher...thereby causing particals of food to remain on dishes.
Thanks
Jun 17, 2010 | Dishwashers
Dishwasher just doesnt get dishes clean anymore. some food left on dishes. there is always water pooled in bottom of dishwasher, but I've cleaned it out well at the bottom
Check your vacuum breaker. Its some times mounted up on the back of your sink. If it gets stopped up it will cause your dish washer to not drain or clean properly. Good luck.
Aug 30, 2009 | Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Glassware and dishes getting water spots lately.
I think your dish washer is starting to go out. We have a Kenmore dish washer (unsure if the model is the same), it started with not cleaning the dishes well to not sanitizing and now it doesnt dry. We are actually replacing ours today. We we noticed that it wasnt cleaning properly (water spots, or not rinsing well) we too added Jet Dry thinking that that would solve it. We soon discovered that it didnt help at all. Hope this helps you.
Mar 17, 2009 | Kenmore Dishwashers
Dish washer is not working
Hi kssami9,
I'm Harvey the Master Plumber.
Your problem is: Your dish washer kenwood model kdw243a is not working and displaying the error code E3 please give you the solution.
First try to reset the d/w. Just turn it off at the circuit breaker for ten minutes.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | EuroTech Dishwashers
Dishwashers Logo
124 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
