Question about Dell E173FP 17" LCD Monitor
Monitor keeps going off.
My Dell Monitor (im unsure of the excact model of the monitor) keeps going black for a couple of seconds, shows the Dell logo & comes back on again.
This is really annoying. please can someone help me out!?
Thanks.
  • KingHowie Feb 04, 2008
    Thanks, its the E173FP.
    But how do i fix the problem?
  • 3 Answers
Try while it''s on to press the menu button and in the top right is the model number.
Posted on Feb 04, 2008
Dell logo won't go away.
If you are lucky a hard power reset will fix this. Disconnect all the cables, hold the power button on for 10 seconds, release the power button, reconnect the cables and turn it back on. Otherwise you may have a hardware problem.
Jul 09, 2017 | Dell E2210 22" Widescreen Flat Panel...
Are soyo monitors compatable with dell computers?
try running it in safe mode tap f5 when you see the dell screen. if it boots to safe mode remove the driver for the display adapter in device manager. the dell computer doesn't know what kind of monitor it's plug into. install the soyo monitor driver
Jun 13, 2017 | Computers & Internet
My monitor is a dell 2000 flat screen 20.1" turns
It is not so difficult to repare if you have scills to open the monitor and scills in un-soldering/soldering electronic components, than yes it is worth it, but if you go to a shop they have a tendency to sell you another monitor since the price they charge to repare the powersupply is about the same as a new monitor
Feb 18, 2011 | Dell UltraSharp 2000FP 20.1" Flat Panel...
My dell monitor will only turn on for a few seconds then it goes black. it doesnt turn of it just goes black and I can keep doing it and it will keep going black.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Dell E193FP 19" LCD Monitor
Cn-ou4931-46633-52L-OHGU - monitor keeps showing
Here you go!
From Dell website:
'OSD Lock': Controls user access to adjustments. When 'Yes' (+) is selected, no user adjustments are allowed. All buttons are locked except the menu button.
All buttons can be locked or unlocked when the 'Menu' button is pushed and held for over 15 seconds. See more here:
http://support.dell.com/support/edocs/monitors/E173FP/En/controls.htm
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 13, 2010 | Dell E173FP 17" LCD Monitor
1905FP Monitor Powers up, briefly shows logo, blacks out.
Look inside for bad caps with bulgng tops, worst case will be shorted out transistors in the backlight inverter circuits or bad lamps. Check to see if you do have he 12vdc for the inveter circuits. See example of failed monitors with bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 12, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor Screen goes black seconds after turn on-
I ended up fixing my problem, but I'm not sure what the solution is. I had some faulty electrical equipment that I was using to power the monitor (220V to 110V converter and a bad power strip) and I got rid of them. I was using the converter because I moved to Israel and I thought I needed to feed the monitor only 110V, but I now realize that the power cord for the monitor has a built-in converter that accepts 220V input. Now the monitor is plugged directly into the wall and is working fine. Try using a different power source (maybe the wiring or plug you're using is faulty). Good Luck!
Apr 21, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Dell E193FPC
Looks like your inverter board is broken.
Similar problem as Neovo F-417 (same chassis) , Look for 715L1283-4 inverter board
Try http://lcdpartsandrepair.com/e193fpc-inverter-power.html
Jun 26, 2008 | Dell E193FPC 19" TFT LCD Flat Panel...
Dell E173FP 17" LCD Monitor Logo
246 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
