Question about Sony Cyber-shot® DSC-H20 Digital Camera
My camera wont charge or turn on - Sony Cyber-shot® DSC-H20 Digital Camera
  • 687 Answers
Sounds like you need a new battery rechargeable batteries can get damaged especially if they are over charged or get too hot or are too old. Some older units are not designed to protect against over current however most are these days.
The adapter is set to provide a constant current to recharge if a new battery starts experiencing the same problems you will need a new charger as this will be causing too much current and reducing the dielectric inside hence no charge being held and hence no volts.
Despite all this advice most Nickel Cadmium will be good for over 1,000 recharges.
Posted on Dec 11, 2009
SOURCE:
Kodak camare wont turn on
same here it wont turn on but it will charge
Apr 18, 2013 | Kodak Mini DVC Digital Video Camera
Camera wont turn on
Often these MUST be charged in an external charger FIRST, as the wall unit is NOT able to "Pump them up" from Flat, but are fine for "Trickle charging" the battery. but will NOT charge up from real Flat. Either that or it is a counterfeit, or bad.
Mar 24, 2010 | Kodak EasyShare M853 Digital Camera
My camera wont start, it wont even charge please help
There is a problem in your battery either you need to replace it or you can try to charge it through USB.
If you want to charge your camera through USB follow the instruction:-
1) In the computer turn OFF the hibernate, sleep or stand by Mode. 2) Turn OFF the camera. 3) Connect the your camera to the computer through USB Cable. 4) Wait for your camera battery to charge (Approx. 3 hours)
This may resolve your problem, Else you need to replace your battery
Rating the solution is highly appreciated...Good Luck
Mar 03, 2010 | Kodak EasyShare MD853 Digital Camera
Camera wont turn on
If you bought the camera in January, it's still under warranty for a year. When you get home call 1-800-OK-CANON to arrange warranty repair. They're usually very good about it, and will try to make things right.
May 29, 2009 | Canon PowerShot SD950 IS Digital Camera
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
Camera just won't turn on!! :)
Katie take it back to where you got it places like best but some time will just give you another camera no questions asked.
Apr 19, 2008 | Samsung Digimax L730 Digital Camera
Sony Cyber-shot® DSC-H20 Digital Camera Logo
195 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
