Question about Dishwashers
Touch pad to switch wash cycles is not working
  • 96 Answers
The touch pad is bad
Posted on Dec 12, 2009
2 Suggested Answers
SOURCE: Most of buttons on touch pad are not working.
Gee thanks McGyver, I'll get right on that and after I'll use any remaining parts, a comb and of course a paperclip to build a rocket. Have anything a bit more practical for the rest of us on planet earth?
Posted on Apr 07, 2010
MDB 8750 Dish Washer Doesn't start the Wash Cycle.
Yes this can be a touch pad failure that may need to be replace again , because with this type of device usually the touch pad is easy to get bad...
Good luck........
Aug 19, 2008 | Maytag Dishwashers
DOES NOT SWITCH FROM WASH TO DRY. CONTINUES TO WASH TO INFINTY IF NOT MANUALY STOPPED
You need a new touch pad... If you can`t switch from wash to dry or any cycle
Mar 22, 2011 | Kenmore Dishwashers
How can i fixed the washing machine with error f21?
You did not specify what machine you have. My literature lists an error F21 as a CCU/Touched-pad/LED assembly error. This error occurs if the touch-pad/LED assembly is not able to transmit/ receive data from the Central Control Unit (CCU) Procedures:- 1. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding. 2. Unplug the washer or disconnect power. 3. Check wire harness connections to the touch-pad/LED assembly and CCU. Replace failed components.
Mar 08, 2011 | Washing Machines
Control locked light is on.Can not start the cycle.
Open and close the door. The door has to be opened between consecutive wash cycles.
2. Check the door switch 3. If Door is Locked, Drain the Unit. 4. Check the wire harness connections. 5. Check the touch-pad/LED assembly.
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The water is not fully draining from the wash cycle. flashing F1,F21, 5D, please advise. Washer was purchased two years ago. thanks
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/proceedure:
2. Unplug washer or disconnect power.
touch-pad/LED assembly and Central Control Unit (CCU).
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
¦ If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
First remove the bottom panel and grab yer tech sheet. It gives the faluts and directions to diagnose or correct as shown above. Clear the pump filter.
Watch this video that shows how from my main man Double H
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cannot program a cycle at all,
Contact the service provider. It could be pad problem or other circuit problem.
May 24, 2010 | Electrolux EWDW6505GS Fully Integrated...
Code f21
1. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding. 2. Unplug washer or disconnect power. 3. Check wire harness connections to the touch-pad/LED assembly and Central Control Unit (CCU).
May 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Problem diagnosis please
touch pad is stuck on the control panel machine putits self in self test
Mar 03, 2008 | Washing Machines
Dishwashers Logo
Top Dishwashers Experts
