Question about LG WM-1485FHD Front Load Washer
Washing Machine Problem
I have the above washing machine and have done for about 3 years now it has worked perfect up until yesterday when the machine stopped mid cycle (leavinbg the fabric conditioner in the drawer) and now won't turn on we have checked the fuse in the plug etc to no avail. We also have the tumble dryer in this range and I know from past problems that this has a trip switch on it to reset the machine can u tell me if the washing machine also has one of these or any other suggestions would be useful
The model number of the product is LG Direct Drive WM-14225 FD I have had to put a different product code in the box below as mine is not listed on there for some peculiar reason.
  • Wolfman117 Mar 25, 2008
    Exactly same problem and same machine ?!
  • jammit1 Jun 20, 2008
    I have an LG WM-1485FHD washing machine and for about 3 months I have not been able to get the fabric conditioner to dispense into the washing machine. I have cleaned the drawer and the compartment where the drawer goes and this makes no difference.
I solved my problem ! The machine has a fuse embedied in the circuit board and encased in vibration proof jelly. Nice design guys - good way to rip off your customers ! So. I cut out the jelly to reveal the fuse and soldered a piggy back fuse onto the blown fuse. Job done. Washing machine fixed. Total cost £0.00
(Plumber callout would have been £80. New board £120)
Posted on Apr 29, 2008
  • 489 Answers
It sounds like the control board has failed.  You will need a qualified LG technician to check this out.
Posted on Apr 28, 2008
Hoover 500mb washing machine doesn't 'click' through the cycles
Sounds like your timer is not working correctly. I would suggest replacing it, as there isn't a way to repurchase timers.
Oct 10, 2015 | Hoover Washing Machines
Kenmore washing machine big troubles?
Please list the model number of that machine. IT could be made by several manufacturers for Sears.
Mar 17, 2014 | Kenmore Washing Machines
W820 washing machine
Some markets do have an internal fuse, if it has one it will be right where the power cord runs into the machine, if not then the issue will be with the main control panel.
Mar 10, 2012 | Miele Novotronic Premier 500 Front Load...
Hello. I have a two years old Whirlpool washing
Unless you look underneath it will not be easy to confirm but please check the following.:
1. check if the motor has failed, the housing has come off.
2. checckif the belts have failed and brought it off the pulley.
3. check if the main spindle , pulley has come off from the main shaft.
4.check if theere is any foreign material struck in between the tub and outer cover. Checking with manually must confirm.
5. check aftert he above had been looked into to see if any other issues are visible or audible.
Hope these tips helps.
Aug 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Bush A126Q White and the ''end of programme'' light is staying on
Sorry Jo, I think I may have mis-understood your explanation - is there actually a problem with the machine functioning properly or is it simply that the end of cycle light will not turn off?
If it is the latter then simply turn the dial back to 0 before opening the door from the previous wash, this action tells the washing machine to reset itself as the drum is about to be emptied.
I have the exact machine however as it is graded, it didn't come with any manuals, at the end of the wash I just figured thta this was what I needed to do.
Its almost as if you need to double-declutch the washing machine - return the macine to 0 before selecting another cycle.
Feb 03, 2010 | Washing Machines
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machine does not drain all the water
Hello nsukiwa.
Welcome,
What is the model number?????????????????????
As I am working blindly for you!
Here are some ideas, until I have the model number.
You said, your washer is a Hotpoint type. When emptying the water it never finishes all the water. You have to throw the drain pipe on the floor to drain it dry.
I'm searching for answers to your problem with these questions!!
1. How long is the drain pipe and does it have to pump up higher than the machine to reach the drain?
As if it is in the basement and the drain pipe above it?
In this case you would need an external pump with some machines!
2. Is the water visible in the bottom of the machine when the load is done?
Or do you just detect some water left in the hose?
There usually is some water left in the hose, but it is not supposed to be visable in the machines tub.
3. I have a Speed Queen washer because this machine can pump the water up above the washer for 7 feet straight up to the drain above!
Most machines are not capable to do this!
I am awaiting your answersHuuum
Oct 16, 2008 | Electrolux EW1000i Front Load Washer
Brown, rust-like marks on washing
Hello I got a Bosch ClassXX5 and got the same problem, white clothes seemed Grey and some clothes seemed washed but not perfectly, until I discovered that the washing machine did not heat water anymore; after the end of the wash cycle the clothes were cold as the program was initially setup to 40C°.....
I used to think soaps were not up to the task and changed brand often, sadly a Bosch product letting me down was not on my mind, since that brand for me was above the rest, quality, strong, during in the time, having electric tools from Bosch without any problem for years!
Oct 11, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine
12 to 14 years on an Amana, (speed queen) built is about life on that machine, You need a transmission replacement. major work. You could have the machine rebuilt, which while it is being done, you would need a new belt, pump, brake pads, tub seal plus anything else that is rusted. You would be better off $$$ to replace the machine.
Let me know if you have any more questions. T
May 21, 2008 | Washing Machines
LG WM-1485FHD Front Load Washer Logo
330 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
