Question about iRobot Scooba 380 Robotic Vacuum
Scubba won't disperse cleaning solution - iRobot Scooba 380 Robotic Vacuum
Used sringe to purge cleaning solution and then it started back ejecting solution onto floor.
Posted on Dec 14, 2009
Steam will not travel through hose scunci steamer ss1000
Blocked with limescale maybe? if its heating to correct temperature to disperse steam then I has to be blocked, that or its not heating up to boiling heat
Mar 03, 2014 | Vacuums
Why won't my Kirby carpet cleaner disperse
check all conections are on tight and no brakes in them this link may help you
http://www.goodvac.com/Articles.asp?ID=153
May 08, 2013 | Vacuums
Cleaner will not disperse water or solutiion
Hi Frances,
Please see the link below to the Repair Guide for the ProHeat 2X. This will help you diagnosis the problem you're having with solution not dispersing water or solution;
Bissell ProHeat 2X Repair Guide Troubleshooting and Repair Instructions
I hope this was helpful to you. If you have any further questions, or would like some additional help, please just ask, I'm happy to help you further.
Oct 06, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Floormate does not disperse wet cleaning solution on the floor. brushes and vacuum pickup all work
First check to see that the wheel assembly is not broken. The assembly must move correctly to allow the fluid to be dispensed. Check for breakage at the rear of the wheel assembly where it attaches to the base. If this is not the problem, you may have a defective soap tank.
Jan 22, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
I have a Bissel Proheat Pro-tech. When turn ON the motor running but not work. The belt still good but tho rotor not turn. Please help me to fix.Thanks
Is this the carpet cleaner Proheat?
I have a Proheat 2X and it wouldn't disperse water unless I used the Water Rinse setting. I found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 23, 2010 | Bissell 9200 Upright Vacuum
Powersteamer problems
You need to replace the pump belt. Here is the belt you need and it comes with printed instructions:
Bissell Pump Belt
Feb 03, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
The water doesn't come out. I've taken it apart
The reason the water is not dispersing is because the pump belt is probably stretched or worn. You can get belts and view the manual here:
Bissell 1699 ProHeat Belt and Manual
Dec 03, 2009 | Bissell 1699 ProHeat Clear View Upright...
Can you disperse a water and vinegar mixture with the steam buggy, without causing damage to any part of the unit? can you disperse a water and bleach mixture with the steam buggy, without causing damage...
If you do this the vinegar will likely disperse hard water scale as it cleans the inside of the element. While it shouldn't stain anything it will likely cause sputtering as it breaks down the scale. If your goal is to clean and disinfect a surface that is vinegar friendly, I would consider taking the extra step of spraying the surface with a spray bottle with the vinegar. Bleach in steam might puff back at you in a cloud and burn your eyes and skin so be VERY cautious on the bleach.
Sep 16, 2009 | Tristar SB Steam Buggy Vacuum
Bissell carpet cleaner does not have suction like it should
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic filter with a door on it. Flip open the door and it is probably clogged with hair, carpet fibre, etc.. Clean it out and you should have full suction once again.
Mar 16, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
iRobot Scooba 380 Robotic Vacuum Logo
143 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
