Question about Jazpiper Audio Players & Recorders
I have a Jazpiper Model No: MVR64P I need a
I have a Jazpiper Model No: MVR64P I need a connecting lead with a U.S.B.plug. Could you help?
Need directions to hookup leads
Hi ,
The best way is to get the manual for the motherboard , you can do this by going online and google the make and model of your motherboard , but its somewhat easy , you have the power supply cords you need to plug in and then install your processor or CPU , along with the fan that has a connection lead you need to plug in right next to the cpu ............and really thats it .
if this doesnt work , let me know ............Roy
Aug 06, 2011 | Computers & Internet
Ethernative drivers for d845 gelly
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows
operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Mar 03, 2011 | Intel D845GVSR Motherboard
Hi my ethernet driver has been deleted so i cant go on the internet i need the driver for it plezz help
The driver should be on the disc supplied by your ISP internet service supplier
you might need a nic ethernet driver
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then go control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
hope this helps
Jan 24, 2011 | Computers & Internet
I have a Dell Dimension E520 running Windows XP. I have a Seagate Barracuda 7200.7 100 gb Ultra ATA hard drive (model number ST3100011A) with IDE connections (taken from an old Emachines). The plan was...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 22, 2011 | Computers & Internet
My tv has one sub output socket,but my active sub woofer has a red and white input sockets.what lead do i need to connect it up with?
Sounds like the output on the TV is a phono socket or a jack and the inputs on the sub woofer take banana plugs. You need (or should make up) a lead with a phono or jack plug one and and two banana plugs the other end. (phono plug/socket has two connections and banana plugs just one)
If you can provide the model numbers of the two bits of equipment I can check this for you.
Mar 08, 2010 | Audio Players & Recorders
Connect leads to motherboard
the red and white leads supply power and from the picture they plug in the middle of the right side. white connecter.
Aug 13, 2009 | E-Machines eMachines Refurbished EMA...
What plugs in where at the back of model 32AV633D Does single scart go to ext 1 or ext 2 Where does outside aerial plug in, there are so many ? Sorry but I'm a complete technophobe who is hopeless at...
If you have a cable box or freeview box, your main aerial lead plugs into the box. Then you connect a scart lead from your cable box/freeview box/ or dvr box to ext 1 on the tv. Where the aerial lead plugs into your cable/freeview/dvr box, there may be an aerial out socket too. You could connect a patch lead from the box to your tv as well so you have UHF direcy from your cable/freeview/dvr box to the TV as well as scart
Aug 06, 2009 | Televison & Video
Connections
you will have a mains lead with an electric kettle type connection on one end which plugs into the rear of the screen and another similar lead for the pc.
the video lead from the screen will plug into a small dovetailed shaped connector coloured blue on the rear of the computer ( it can only fit one way round , as its broader on one side than the other )
the speaker leads will probably be small jack plugs one for left and one for right, and they plug into the rear of the computer, audio out / left / right.
Jan 05, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
18 people viewed this question
Top Jazpiper Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Jazpiper Audio Player and Recorder Expert? Answer questions, earn points and help others
