Question about Microsoft Wireless Notebook Optical Mouse 3000
Usb only connects for a short period then
The usb is connected to my computer and the red light on the mouse is working but the USB only connects sometimes, i've fiddled with everything I can to try and make it work but It doesn't seem to work, is there anything I can do?
    Sniper:
  • 50 Answers
Please reinstalled USB driver on your system and thane tri again.
Regard,
Abhay Singh
Posted on Dec 12, 2009
Mouse not working
Mouse is a short life device. If your used it more then replace a new mouse. Because if your repair it cannot succeed. And cost a double charge .. So Purchase a new mouse..
May its cable cannot connected well to computer...
If You have usb mouse change the usb port and place on other usb port... If this not works remove mouse..
If you use ps2 mouse this type of mouse dont detect if your connect on pc on mode.. So restart your computer to find your mouse...
Hope this will help you...
Mar 08, 2013 | Computers & Internet
I tried to connect it to the computer and its not working i dont even know if the computer is reading the usb
Double check that the batteries are in correctly in the mouse, then make sure that the USB is in correctly. Connect the USB to your computer before startup and turn on the mouse. Turn on your computer. There should be a connect button on the usb and/or the mouse. Press both reasonably within a short period of time (5-10 seconds). They should blink and automatically connect. If this doesn't work after a couple of tries, then restart your computer and remove the batteries from the mouse, and start again from the top. If this still doesn't work then bring it back and get a new one.
Mar 03, 2011 | GE Wireless Optical Mouse
Keyboard does not type
If all the keys on the keyboard have stopped functioning follow the instructions below to reconnect the keyboard.
This problem is likely to be a lost connection. The connection between the mouse and the USB mini-receiver or the keyboard and the USB mini-receiver can be lost due to several reasons such as:
  • Low batteries
  • Moving the USB mini-receiver from one USB port to another
  • Moving the USB mini-receiver to another computer
  • Plugging the USB mini-receiver into a USB hub or other unsupported device such as a KVM switch (your USB mini-receiver must be plugged directly into your computer)
  • Using your cordless mouse/keyboard on metal surfaces
  • Radio frequency (RF) interference of more powerful wireless devices such as:
    • Wireless speakers
    • Computer power supplies
    • Monitors
    • Cellular telephones
    • Garage door openers
Eliminate any problem sources mentioned above that might be affecting your devices.
Follow the procedures below to reconnect your mouse and keyboard.
  1. Make sure the USB mini-receiver is directly and securely plugged into a working USB port on your computer.
  2. Make sure the mouse is turned on. The on/off indicator on the bottom of the mouse should be green. If the on/off indicator is not illuminated, press and hold the red connect button on the bottom of the mouse until the on/off indicator is green.
    On / Off Indicator
  3. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your mouse. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  4. Quickly press the red connect button on the bottom of the mouse for 1 second, then release it. The power indicator will flash briefly and then turn green. The mouse is now connected to the receiver.
    Red Connect Button NOTE: Holding down the red button on the mouse for more than 2 seconds may cause your mouse to turn off instead of connecting. If this occurs, start again at step number 2.
  5. Move your mouse to see if the cursor moves. If the cursor follows the mouse movements, your mouse is now connected.
  6. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your keyboard. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  7. Quickly press and release the red connect button on the underside of the keyboard.
    Keyboard Connect Button
  8. You will hear a short beep. The keyboard is now connected to the receiver.
  9. Test your keyboard to see if it is working. If the mouse now works but the keyboard still does not, see Knowledge Base article 9144.
Dec 14, 2010 | Logitech Cordless Desktop MX3200 Laser...
My mouse is freezing time to time.it works perfectly for a period and at a moment it's start to freeze. the freezes are not the same:some are shorter,some are longer and some times i have to remove it from...
Try to use a differnt usb port sounts like a possible conection shorting on the mouse cable its self, if u shake mouse to try create this error and error apears then there is a conection fault goign to mouse and it is shorting out the usb.
Get new mouse :P
Nov 28, 2009 | Razer Diamondback 3G Gaming Mouse -...
Not working
dear,
The small notch in usb device socket under the mouse could be malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
regards,
dont forget to rate it
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
Mouse optico doesnt work
dear,
The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
regards,
hope it will fix your problem
Jun 27, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse Not Connecting
After reading on Microsoft about replacing the batteries, down loading drivers and "press the button on the receiver and the connect button the receiver" - I got frustrated and almost gave it flight. Then my wife stepped in and realized that there was a green reset button on the USB connector as well. (who knew?) SO.... you press the green light (which is a button) and release it.... should blink. Then go to THE MOUSE portion and press the connect button for 5 seconds or so.... and wala...... One mouse that plays again! This ones gonna cost me! :) I hope this one works for ya!
Apr 05, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse 3000 Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
