Question about Kenwood KAC-9102D Car Audio Amplifier
When i hooked the amp up the it would blink red right when i turn the stereio on
    Scholar:
  • 84 Answers
This can be caused by a short or a non constant current from your head unit to your remote power wire on your amplfier (your remote wire might be broken some where). Or your amp is losing ground. also check your speaker wiring and so on. www.the12volt.com has a subwoofer wiring diagram for all occasions.... make very sure you are wired properly this can be killing your amp causing the light to dim and so forth...
Posted on Dec 13, 2009
RED BLINKING & BEEPING LIGHT COMES ON WHEN I TRY TO TURN ON
I would go back to make sure that its plugged in correctly. What is your PC doing when you see the Red blinking light on your hard drive? Do you hear any beeps?
Feb 20, 2013 | Computers & Internet
Sony trinitron kv-es29m80 tv has no led light
The blinks are fault indication. If the standby light blinks 10 times and the set shuts down after that;
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Apr 12, 2012 | Televison & Video
I just got my PPI dcx 300.2 amp back and i hooked it all up, and connected the fuse back in and started the truck, the amp turns on but the red light starts blinking and says clip out. The amp doesnt smell...
Are you sure everything is correctly connected. If you are running the amplifier in bridge mode then take note that the load to the amplifier can be no lower than 4OHM. dreamsystems
Feb 25, 2011 | PPI DCX-300.2 Car Audio Amplifier
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Wireing diagram to hook up amp sub and 4 speakers
Here's the color codes for the wires.
Blue=power antenna
Blue/white=remote turn on for amp
Red=ignition
Yellow=battery
Black=chassis ground
Grey=right front (+)
Grey/black=right front (-)
White=left front (+)
White/black=left front (-)
Violet=right rear (+)
Violet/black=right rear (-)
Green=left rear (+)
Green/black=left rear (-)
RCA Connections:
Red=right rear to amp
White=left rear to amp
And that should be all the wires. Good luck!
Sep 26, 2010 | Alpine TDM-7582 Cassette Player
Playstation wont start. light turns from red, to green, to yellow and then to a blinking red. what's going on?
The first thing that you need to thoroughly check is the cables. Most the times this problem arises because of the cables not being properly hooked up. Although this may sound very basic, yet it is something that most people tend to ignore.
Just in case the cables are properly hooked, the next thing that you need to check for is any damage in the cables. If you find that the cables are all right, then you need to check your TV’s resolution. These are some of things that you need to look for whenever you find your PS3 blinking red.
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
Onkyo receiver HT-R530..after cable and speaker hook up = puff of smoke and blinking red light. Will only turn on for 10sec at a time. Whats UP!???
One way or another, it sounds like the amp has blown. Probably the outpous and/or drivers and such. Perhaps one of the speakers was either shorted, wires touching or hooked up wrong.
Oct 09, 2009 | Onkyo HTR500 Receiver
Pioneer GM-7200M power problem
Check your GROUND wire might be touching something and making bad contact.
Jun 09, 2009 | Pioneer GM-7200M Car Audio Amplifier
Turns on then off with blinking red light
turn on your ps3 but keep your finger on the touch sensitive on button for 5-7 seconds, the sytem will beep again and all pictures are back to standard def. worked for me, so should work for you. good luck.
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
Red light on the amp.
Have you checked your speakers to make sure they're connected to the amp (a wire could have broken or pulled loose)?
Have you confirmed that you have a good signal reaching the amp?
The red light isn't always a good indicator that the amp is functioning properly. If you have speakers connected to the amp and have a good signal feeding the amp, the amp may have failed.
Dec 22, 2007 | Pioneer GM-7200M Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
145 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
