Question about Maytag Ovens
HOW DO I GET THE TOP OFF MY MAYTAG RANGE MODEL # 6898VVV. SO I CAN REMOVE THE ELECTROIC CONTROLLER.
Figured it out myself.
Posted on Dec 12, 2009
SOURCE:
Where do I find my model number on my Maytag range?
their have an sticker may be in steel where your model number and company name have.if no sticker then you can find it back side of maytag range.
May 30, 2014 | Maytag Ovens
I would like to remove the fuses that control the stove top on my Maytag oven so that i can use only the oven. ( i do not need to use the burners and do want to risk turning on the range top because i...
Hello, there no such thing as a fuse to control the top burns, if your Maytag is gas or electric.
The gas goes through a regulator to keep the range gas pressure @ 2lb. Then gas goes into aluminum manifold system for the top burners where each burners has a fuel valve in the manifold. Off of this manifold is another aluminum pipe with a little adjustment valve for the setting the flame on the oven burner in the oven.
Mama, it sound really dangerous with you stacking things on top of your kitchen range. Even when the oven is on it will vent hot oven air in the back of the top of range. Are you familiar with the Fire Triangle. Fire...needs three things, fuel, air, and ignition to burn. I hate to say it, but you have all three of these component to have fire in your home. By stacking things on top of your kitchen range.
Now, just a little word of advise here. DO NOT STACK STUFF ON or NEAR your kitchen stove, heater for you home or even around light bulbs and power cords. Ms. it seems that you are a very intelligent young lady. Just remember the FIRE-TRAIANGLE----it could possibly safe your live and home. I wish you many years in your life experience through time. God Bless...stewbison
walk gently up on this earth, and she will be good to you....
Sep 08, 2011 | Ovens
The on indicator light for the range top will not turn of when the burners are all in the off position
The model number given is for a wall oven so I'm a little confused about the question. If you have burners on a range top as stated in the question, the on light for the burners is controlled by each individual switch. One of the switches has a stuck contact that is keeping the light on. You would have to determine which switch is stuck and replace that switch. Once that switch is replaced your problem will be solved.
Aug 29, 2011 | Maytag CWE4800A Electric Single Oven
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
Started oven to bske brownies - started beeping and the letters F-3 came up?
F3 is a bad temperature sensor.
Unplug the range. Remove the oven racks. Look up high in the rear portion of the range oven for a thin metal piece about 4 inches long. Remove the screws and remove the temperature sensor for replacement.
Parts can be found at repairclinic. com .
Enter your model number found inside the pan drawer to look up the temperature sensor.
Dec 31, 2009 | Maytag Ovens
I have a Maytag Electric Range/Oven The Range MODEL#MER5755QAW
best guess is thermostat I believe the broiler does not need the thermo in oven.. it stays on steady hot .. thats why it still works
Mar 12, 2009 | Ovens
Range is shuting off
wen it became hot the water content from air turned it off.
Jan 02, 2009 | Maytag 30" Built-In Single Electric Wall...
Oven stop working
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
May 21, 2008 | Maytag Ovens
Ovens Logo
Top Maytag Ovens Experts
Carmen Mikulic
Marvin
Marvin
Sal De
Are you a Maytag Oven Expert? Answer questions, earn points and help others
