Question about Visioneer PrimaScan Colorado 2600u Flatbed Scanner
I need a power supply to plug it in. What make should I look for?
  • 28 Answers
Power requirement is 12 VDC 1 amp.
I need a power supply to plug it in. What make - need-power-supply-plug-in-make-sgxq54zelg5vrss35wgruntt-5-2.jpg
Posted on May 03, 2015
Power plugs on newer equipment require only a standard ac power plug
but older type scanners and depending on manufacture make the with special plugs and with power transformers that cut voltage down and designed for power to run proper amps and voltages ac/dc.Finding the right one may require going to factory or on e-bay in hopes finding another power supply.Sometimes you can buy a used one for the price of a power supply.
Posted on Dec 11, 2009
Will not start
smor4u,
There is no reset or fuse to reset. You may need to get replacement power supply. If the computer is plugged into a power strip or surge protector you can bypass it and plug the system directly into a wall outlet and power up.
Power Supply Light-on the back of the computer.
The light is a Green Light by the power supply.
Power Supply light is lit by a signal in the power supply called Power_Good (PG).
If the Power Supply Light Led is not light up, the power supply is defective.
If you need to replace the power supply you can contact the Dell Spare Parts Department at 1-877-717-3355bsat4ube4gblqiaaaaasuvork5cyii= or click the link below.
Dell Spare Parts
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 15, 2013 | Dell Vostro 420 Desktop Computer
I lost my driver and what kind of power supply i need?
if you want to change Power Supply, that not need driver, you just un-plug all power connection, and change with New Power supply, and Plug like begin you unplug before.
Mar 02, 2011 | Computers & Internet
Hi, my HP Pavillion a1240n won't start up... the wall plugs work and the power supply is plugged in but no lights are showing. I've also been flipping the switch beside the power supply at the back, and...
There are only certain items that will not power up a machine. 1. The power supply itself could be gone. 2. Check your ram. 3. Your hard drive. In most cases it is the power supply. Take out the power supply from the machine and plug it in to a wall socket. If it starts that it is not the power supply. If it doesn't start replace the power supply.
Dec 05, 2010 | HP Pavilion a1240n (EG136AA) PC Desktop
Can you supply pinout for Dell AA23300 Power Supply ?
On the main plug there is a single green wire. Jumper the green wire to any black groung wire in the plug and the fan will start and you will have output.
Nov 03, 2009 | Dell AA23300 550W Power Supply (X0551)...
When installing the power supply on the emachine t4510, where do all of the plugs need to be placed. i got one that didn't have a power supply. i picked up a power supply and i'm not sure if i pluged it in...
there is a big white connecter in smps (powercable }it connect in board. there is power cable need for optical drive/ hard disk/ from smps we supply in only bord / hdd/optical/ we connect cpu fan from bord.
Oct 14, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
What does the p10 plug into??
  1. ATHENA POWER AP-P4ATX30 (APP4ATX30) 300-Watt Power Supply - Product ... Detailed specs for ATHENA POWER AP-P4ATX30 (APP4ATX30) 300-Watt Power Supply at mySimon ... POWER AP-P4ATX30 (APP4ATX30) 300-Watt Power Supply. Sponsored ...
    www.mysimon.com/9025-11545_8-32862239.html - 48k
Aug 21, 2009 | ATHENA POWER AP-P4ATX30 (APP4ATX30)...
I plugged the printer into 220 volts inlet ,burned power supply
Cheaper to replace the machine than buy a power supply - unless you find a parts machine somewhere.
Mar 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
COMPAQ 272776-001 Power Supply 200W
They all do, I believe, I installed a new one, into my computer system not long ago, are you sure your power supply is one that the computer can handle? You shouldn't have that much of a problem - I wouldn't go pulling apart the wires on the power supply, its made like that for a reason, what you could try is see if your power supply has seated properly, sometimes if your not working on a flat surface the power supply plug won't go in properly and will not be pushed in all of the way, try laying your computer on its side, and pushing in the plug also, each motherboard has a certain amount of plugs for example 20 and 24, some motherboards want it to be a 20 power plug and others want it to be 24 power plug, thats the plug thats connected to your motherboard, that I'm talking about. make sure you have the right number, and that the motherboard plug and the power supply plug match, basically have the same number of connectors, (I mean that little white plug at the end of the red,yellow,black, wires, I hope this helps. ps- I really had to push on the white plug to get my seated properly
Mar 05, 2009 | HP Compaq 175-Watt Power Supply
Im looking for a plug to put in a wall socket and im trying to use an older cobra29 cb radio. Can you help?
Hey AlexJacob
a mobile cb radio like the cobra 29 requires 12V DC, to plug the radio into the wall you need a Power Supply. A small 5 amp power supply will help you. Their is no plug that goes Directly from a Mobile CB rado into a wall. You will need to plug a power supply into the wall, Then take the power chord (red and black with 3 prong [o oo] and connect red to red on the power supply and black to black on the power supply. Unfortunatly a cheap power supply will be $50+ check your local radioshack
Jan 09, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Visioneer PrimaScan Colorado 2600u Flatbed Scanner Logo
153 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
