Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
I turn on the dyna pro rmc kfa65t pro i turn it on and the fan kicks on and i see fire from the ignighter but the heater never kicks on whats wrong with it
  • enerkem May 11, 2010
    do you mean the blower fan never kicks on?
  • 3 Answers
SOURCE: Dyna Glo Pro RMC-KFA70TDGP 70,000 BTU Torpedo heater not igniting
The main circuit board supplies ac power to the ignitor ( black transformer looking device) and the transformer increases the voltage that is supplied to the sparking device. Make sure the wires are connected to the sparking device and the ends of this device are approximately 3mm apart and that it is in the general position near the end of the nozzle. If you do not hear a "clicking" sound it could be the main board, wires or sparking device.
Posted on Dec 17, 2008
  • 58 Answers
SOURCE: Does anyone know where I can source a manual
TRY www.sengokula.com/manuel.htm I PUT IT IN MY SEARCH ENGINAND HAD ABOUT THREE PLACES THAT HAD MANUUELS GOOD LUCK
Posted on Jan 25, 2010
  • 224 Answers
SOURCE: When turning on My dyna
I have several of these in my shop. When they act up it is usually carbon deposits blocking the fire eye. This is a sensor that detects flame, if no flame is present it shuts down the whole heater. Remove the upper cover of the heater and attempt to start it, watch for 1- spark from the ignition sorce 2-fuel being sprayed from the atomizing nozzle 3-ignition of fuel. No spark bad spark plug or ignitor, no smell of fuel or small cloud of fuel, bad fuel filter, no fuel, bad fuel line, bad or plugged nozzle. There are several things that cause this but these are the three most common problems I encounter.
Posted on Dec 10, 2010
  • 7 Answers
SOURCE: The fuel pump came apart
The first thing you need to determine is the correct model number of your heater (there's a couple of KFA125TDGP heaters, so make sure you get the correct manual). Once you've done that, go to the GHP Group Inc, website listing the heater manuals and locate the appropriate manual for your heater model and select it.
After you've selected the appropriate manual, you can either download it to your computer or print it out. Inside the manual you'll find exploded views, parts lists, troubleshooting, and instructions. When you locate the items you need to replace, contact your local authorized service center for the replacements (it might be quicker to pick them up than having them shipped to you from the manufacturer). If you don't have an authorized service center near you, you may call the company directly at: (877) 447-4768.
Hopefully, you'll have your heater up and working again in no time.
Posted on Jan 13, 2011
SOURCE: I need a new ignitor
Please call me at 866-883-9312. I have an ignitor in stock that will work for you. The price is $58.99 + $9.75 for shipping.
Thanks Bill
Posted on Jan 27, 2011
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Need a control knob for: dyna-glo pro propane heater. model: # rmc-tt30dgp-01, # rmc-tt30dg, # rmc-tt30gd. this is the off/low/med/hi temp. control knob.
I AM TRYING TO FIND A PROPANE REGULATOR FOR A DYNA-GLO PRO. THE MODEL # IS RMC-TT30DGP. THERE IS A NUMBER ON THE OLD REGULATOR. THAT # IS S2NTT0002-2.THANK YOU.
Dec 17, 2010 | Heating & Cooling
Dyna glo pro model #rmc kfa 125tdgp flashing code e1
I have same heater and problem-1) Check fuel inlet screens at bottom of hose in tank 2) Check air filters at fan module opposite end of the fan blade 3)Check for spark in ignition chamber 4) Check for fuel flow in ignition chamber (look at pressure gauge at opposite end from air exit) You'll have to remove the top cover to do these checks. The side covers will hang on each side ok. I hope these checks help you out.Good luck.
Jan 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
I have a Dyna Glo-pro multi fuel heater. When I turn it on the ingitor starts working and than the fan comes on for a few seconds. Then the system shuts down because it willnot ignite. The tank is full and...
Since it does not ignite, Please check the ignition transformer. This have a secondary voltage of about 20,000 to 25,000 volts, enough to make your igniter
spark, thus, causing the atomized fuel to ignite and burn the fuel. So, please include igniter high voltage cable for ground leak. Ground leak is visible as line sparks when your heater is switched on. If your ignition transformer does not produce sparks at the
igniter, it means it needs to be replaced.
Have it done to make it work. Hope this will help you.
Jan 10, 2010 | Dyna-Glo RMC-8001SS Heater
Dyna-Glo model RMC-8000PGH will not stay lit
Your pilot safety is full of dust. Flush it out with shop air or rust buster. Retry
BONUS INFO
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 17, 2009 | Dyna-Glo RMC-8001SS Heater
Had heater sitting in garage for 2 years and now it wont fire-up. i can smell propane and theres pressure when i take off tank. whats wrong? oh yeah i have spark to.
Alway clean the unit first before starting cause little critter could block fuel flowand spew out instead of where it suppose to go!
Kerosene heater
Dyna Glo 95 c4 Manual
http://www.owneriq.com/mdownloads/8979e0af-dfee-45f1-a8ba-c05c2f5ed4a8.pdf
Jan 31, 2009 | Dyna-Glo RMC-8001SS Heater
Dec 16, 2008 | Heating & Cooling
I have no manual and no clue
After not finding any help on the Internet, I went to Home Depot to see if they could help. I deduced through my own that the ignitor has failed. (symptom: Turn on the heater, no buzzing, no ignition, heater turns off, light blinks). It's the nifty little black box that has two white wired leading to the circuit board, and two thick black wires going to the spark plug. Of course, Home Depot doesn't carry parts.
They had one Dyna Pro heater on the shelf. My wife found a phone number on the box. We called it and sure enough, we found the company and was able to order the replacement ignitor over the phone. Total cost: $33.00 (Including shipping).
IS HELP OUT THERE. Here's the info:
GHP Group.
7500 Saint Louis, Skokie, IL 60076
1-877-447-4768
The replacement part is part number: 39E0002500
It fits models: RMC-KFA125TDGP, RMC-KFA170TDGP, and RMC-KFA70TDGP
Hope this helps.
Nov 20, 2007 | Heating & Cooling
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
266 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
T bone 1963
Craig Butler
Craig Butler
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
