Question about Bugaboo Cameleon Jogger
Seat Positions Won't lock
The seat ratchet system won't lock into the different positions. We were advised to loosen the screw behind the mechanism and apply the lubicant. It doen't appear to have improved it. Any suggestions?
  • 3 more comments
  • dustytrev Feb 10, 2008
    I have the same problem. It happened when i tried to get the seat fabric in place. I was putting a lot of force to squeeze frame to allow the O-rings to fit.
    I am worried I crushed the buttons.
  • othertrev Jun 05, 2008
    Same problem. We have "crushed" in the buttons and they won't pop back out. Have disassembled the mechanism but no luck. Will try sanding down the buttons but not sure how it will work out - it seems to stick from within and not from the edges of the button. Stay tuned.....
  • Anonymous Aug 27, 2008
    The two white discs no longer pop back out on my bugaboo cameleon when I try to lock the seat into position. this makes the pram unusable. any suggestions?
  • Anonymous Oct 18, 2008
    We have the same problem with the Frog I tried a lubricant but no luck. For the amount of money that was spent on this stroller, I am surprised how poorly it is holding up (we have had flat tires, other jammed locking parts) after less than a year of light use. I guess I am going to have to get out the tools again.
  • Pongomum Oct 25, 2008
    We have the same problem, sometimes the white circles pop out and hold the seat in the right positions and sometimes they don't - it's really frustrating and I am going to take the buggy back to where I bought it from and hope that they can help...
I had the same problem, It looked like some irregular wear on the with buttons or sand or dirt trappped. I took the screw out of the mechanism, dissasembled it and used a screwdriver to push in the tabs that hold the button. With the button out I sanded all round the edges of it, starting with some coarse paper and moved to find to make it nice and smooth, lubricated it and reassembled. Its a bit fiddly to get back together but there does not look like anything is going to break or get lost.
Works ok now. This would probably void your warranty, but we had lost our recipt and it saved a big repair bill. Took about 45 mins.
Posted on May 08, 2008
    Novelist:
  • 126 Answers
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: service@us.bugaboo.com
WEB SITE: WWW.BUGABOO.COM
Posted on Apr 28, 2008
Driver's car seat back will not lock in upright position
Mechanism most likely broken . I had a Hyundai and was rear ended and the mechanism broke plus I know of several other seat backs that broke on people
Jun 06, 2016 | 2009 Honda Accord
Seat back won't stay up
Probably has a broken or jammed lock When you position the seat try pulling/pushing the handle instead of relying on the spring to engage the lock. If the seat frame is broken remove it for repair or replace with another seat back
Feb 22, 2013 | 1998 Toyota Corolla
Ford Expedition second row seat stuck in folded down position
dealers repair book best option/mechanics manuals may find online
Dec 12, 2012 | 2004 Ford Expedition Eddie Bauer
Mx-5 belt won't pull out
the seat belt has a spring and can become twisted and not completely go back in on its self you need to pull the seat belt all the way out, and slowly let it back in it should reseat its self make sure there is no twist overs while it goes back in.
Jul 15, 2017 | Mazda MX5 Cars & Trucks
Passenger seat won't lock in place
The adjusting lever for seat position is not locking into place. On the bottom of seat are runners on each side with holes in them that the adjusting lever tabs will lock in and hold seat in place. The seat slides on the runners if those tabs are raised. There is also a connecting wire or rod from the lever to the other side of seat so when lever is pulled up, tabs on both runners are raised for seat to slide. Something is keeping the tabs from locking into the holes on the runners in your car. Maybe the adjusting lever is broken somewhere, or the wire/rod came loose, or the lever is just dry and sticky and needs a shot of WD40 to loosen it up. If you can't see it and fix it with seat in place, then pull the seat back off for the repair. Good luck. Post back if my explanatiopn is not clear or you still need help.
Jun 19, 2012 | 1998 BMW Z3 Roadster
I have a 99 Silverado and the passenger side seat back will not lock back into the upright position. Locks fine into reclining positions. What could be the problem?
i had this problem on my 96 chevy, basically theres a set of ratcheting gears that lock the seat in place in the various positions. sometimes over time or due to abuse one side or the other gets stripped out and the seat will no longer lock into place. i found a ripped up seat on Craigslist that was in a part out truck and bought it cheap then took both seats in the an upholstery shop, between the junked out seat (15 bucks) and the labor at the shop (50bucks) it cost me 65 bucks to fix, hope this helps
Mar 13, 2012 | 1999 Chevrolet Silverado 1500
Why won't the driver's seat on my 2006 XJ8L won't adjust in height?
You have a problem with the power seat transmission. The 1st thing to do is make sure that nothing under the seat is impeding the movement of the seat, if that is OK you will need to try and find a used power seat transmission, the parts are not sold separately, just the whole assembly.
Feb 13, 2012 | Jaguar XJ8 Cars & Trucks
Back seats won't fold down 97 toyota camry
The plastic pull on the top of the seat may have been screwed down too much. If that happens, it will not allowing the lock mechanism to fully unlock. Unscrew the top plastic pull a little at a time and at the same time reach around and pull the lock leaver up until it is in the full unlock position. You should then be able to pull the plastic lever up normally and fold down the seat.
Nov 08, 2011 | 1997 Toyota Camry
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Bugaboo Cameleon Jogger Logo
251 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
