Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
We have a round thermostat made by Honeywell. I
We have a round thermostat made by Honeywell. I would assume it is from 1992 or thereabouts ... the temp is set at 70 and the heat doesn't turn on even at 60. We notice that there is a ''dial'' on the inside of the round cover that has a thin metal 'arrow' pointing where numbers are printed on a metal band. Is this the threshhold for upper/lower temps? And if so, how do you adjust it????
  • Honeywell Master
  • 43,501 Answers
The thermostat that you have is position sensitive. By that I mean that you need to have it in the right position for it to work correctly.
When you have the ring off of the thermostat loosen the two little screws and pull the thermostat away from the subbase. On the subbase you will see a line that needs to be level. If it is not level then the mercury bulb will not be in the right position to start and stop the furnace. Level the subbase and reassemble the thermostat and your furnace should start to work properly. If not then the thermostat is probbaly bad.
When they go bad it is often becasue ot the little arm that you refeered too. That is a small heater than actually fakes the thermosat into thionking that it is hotter in the room then it really is. This makes the furnaces shut down a bit early to combat overshoot. Adjusting that will determine how much time before the furnace hits the shutdown temperature that it will actually shutdown... got that?? In others ward it is probably a good idea not tp mess with that unless you know what you are doing. However the heater can burn out and create problems.
So, check that the thermostat is level and if not get a new t-stat...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Posted on Dec 11, 2009
I have a honeywell T87K round thermostat (2-wires R and W). I just purchased a honeywell WIF 7-day programmable thermostat RTH6580WF. How do I install the new thermostat? Is it even possible?
Programmable is in unit nothing to do wire fto urnace two wires cut furnace on and off you should have instructions to use two wires with your instructions
Aug 18, 2015 | Honeywell T87K1007 Mechanical Thermostat...
Round honeywell thermostat
Sounds like you have a T86 thermostat...take the round front cover off to view the Mercury switch. Watch the bulb when you change the temperature to a higher setpoint. If the bulb makes contact when rotating it up, and the furnace doesn't go into a call for heat, then it could be the thermostat, wiring, or furnace problem.
Dec 13, 2013 | Honeywell Heating & Cooling
Honeywell programmable thermostat - was installed per instructions in manual and now the furnace runs non-stop unless I move switch to "off." The old (round mercury switch) thermostat was wired red t
If you are unsure about which wire goes where, that may be the source of your problem. The color coding can be confusing when changing from old to new. I pulled the instructions for my Honeywell CT3400A thermostat and found you can call Honeywell Consumer Services at 1-800-468-1502 M-F 7:30 am to 5 pm CT
Mar 11, 2013 | Heating & Cooling
Honeywell Thermostat Lock Cover
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 31, 2010 | Honeywell Electronic Programmable...
HONEYWELL T87N 1000 ROUND THERMOSTAT
the power for that stat comes from the furnace - if you have no display on the stat you have a furnace problem
Sep 28, 2009 | Heating & Cooling
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Why can't i get my thermostat to work
HONEYWELL WEBSITE:
Go to honeywell.com
Oct 22, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Jan 14, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
383 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
