Question about Canon PowerShot A540 Digital Camera
Memory card error
Cut camera on and get memory card error
  • Canon Master
  • 4,738 Answers
On the old Powershot S400, this error was caused by a dead internal "clock" button battery. Fixing it required simply replacing the battery. But before you attempt to do that, would first suggest trying a different memory card.
Posted on Jan 21, 2008
My cam says "memory card
If the camera displays Memory card error or No Memory Card when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. If this is the case, you may wish to Format the memory card in the camera using the Setup Menu option [Format] as shown below. Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data. This can also be caused when images shot with another camera are stored on the memory card.
If after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service. If the card appears to be defective you may wish to contact the memory card manufacturer.
Thank you!!
Sep 04, 2011 | Canon PowerShot SX210 IS Digital Camera
When i turn the camera on it says memory ard error
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 01, 2010 | Optics
Canon ZR200 memory card say ''card error'' when inserted. Card is not locked. I have formatted it. Have used 3 different sizes of cards. Sometimes it will say ''card error'' then start working a couple of...
Sounds like the contacts for the cards are dirty. Turn off the camera and remove the batteries before doing the following.
Try taking a piece of card stock (or a manilla folder) and cut it to the size (width only) of your memory card. Fold it to make it thicker. Wet the creased end with rubbing alcohol. Now gently insert the creased end into the memory card slot and move it in and out to clean the contacts. Remove and blow out with a can of compressed air to dry. Let sit a few minutes and then your cards again. You might want to clean their contacts as well with a clean rubber type eraser by gently rubbing the contacts on the cards.
Feb 01, 2010 | Cameras
How can I solve write protected on memory card ?
If the error is actually that the card is write protected this will help.
You should see a small slide on the side of the memory card.
Slide it towards the top of the card, the top being where the 45 degree cut is.
This is the card write protect slide.
Jul 10, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
File errors, distorted photos.. I hate the Samsung L100!!
regarding the use, you have to check if you are using the right memory card for your camera.
you can only use 2GB sd card or 4gb sdhc card.
try this and if you still have an error message. you better send the camera for service.
Jan 19, 2009 | Samsung L100 Digital Camera
Memory Card Error after Formating memory card
instead of quick format, use the full format.  Then put back in your camera and format again with the camera.
Oct 26, 2008 | Pentax Optio S40 Digital Camera
Canon Camera - Memory Card error & Card locked error
Try reading the card independent of a camera i.e. on a computer or a photo kiosk to determine if the card is readable damaged
Jan 07, 2008 | Canon PowerShot A410 Digital Camera
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
Samsung S630 Digital Camera, Card Error and Format Error
you have several options:
1. see in the specification details of your camera what memory card is compatible for camera. for S630 it is SDHC/MMC/SD card (Up to 4GB Guaranteed). see if you're using memory card within this capacity and type. If you're using a different memory card type and capacity, try to use memorycard that is compatible with your camera.
2. try to use memory card to other devcie like cameras, cellphones and other devices and if it still has error problem, your card may be the one defective. use other cards.
3. try to take pictures without using memory card. use only the internal memory of camera. if camera still display this error meassage, camera needs service.
hope these options solve one of your problems. c",)
Dec 29, 2007 | Samsung Digimax S630 Digital Camera
Poloroid camera 3070
Unless the camera has an internal memory[does it?]it will need a memory card to operate. Then manual will tell which or the makers website tech help or the shop you purchased it from
May 26, 2007 | Polaroid PhotoMax PDC 3070 Digital Camera
Canon PowerShot A540 Digital Camera Logo
239 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
