Question about Panasonic Panafax UF-790 Plain Paper Laser Fax
HOW DO YOU SET THE DATE ON FAX MACHINE MODEL UF790
  • Panasonic Master
  • 1,297 Answers
Enetr in the user mode and select the date /houre.
Posted on Dec 11, 2009
How do I change the time on the Brother 2820 fax?
This was taken directly from the Brother 2820 Manual:
Setting the Time
When the machine is not in use it will display the date and time. If you set up the Station ID the date and time displayed by your machine will be printed on every fax you send. If there is a power failure, you may have to reset the date and time. No other settings will be affected.
1 Press Menu/Set, 0, 2.
[2. Date/Time]
2 Enter the last two digits of the year.
Press Menu/Set.
3 Enter two digits for the month.
Press Menu/Set.
(For example, enter 09 for September,
or 10 for October.)
4 Enter two digits for the day.
Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format.
Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time
whenever the machine is idle in Fax
mode.
When the machine is in Sleep mode, the
LCD shows Sleep. (See Sleep Time on
page 2-8.)
Turning on Automatic Daylight Savings Time
You can set the machine to change automatically for Daylight Savings Time. It will reset itself forward one hour in the Spring and backward one hour in the Fall. Make sure you have set the correct date and time in the Date/Time setting.
1 Press Menu/Set, 1, 5.
[5. Auto Daylight]
2 Press Up Arrow or Down Arrow to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
May 03, 2011 | Brother IntelliFax-2820 Laser Fax
Hello we have a Brother 2820 Fax Machine and we cannot find the Instruction Manual and we need to reset the time can you please advise us on how to do it. Thanks Marie
1Press Menu/Set, 0, 2.
2 Enter the last two digits of the year. Press Menu/Set.
3 Enter two digits for the month. Press Menu/Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day. Press Menu/Set.
5 Enter the time in 24-Hour format. Press Menu/Set.
6 Press Stop/Exit.
The LCD now shows the date and time whenever the machine is idle in Fax mode.
When the machine is in Sleep mode, the LCD shows Sleep. (See Sleep Time on page 2-8.)
Hopefully that worked correctly and solved your problem!
Apr 07, 2011 | Brother Office Equipment & Supplies
ADF won't pickup paper off Panafax UF790
Open the ADF door and clean rollers and ADF pad with windex sprayed onto a paper towel , if problem remains call service tech to replace parts required.
Sep 29, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
Is there an Error Correction Mode on the Panasonic Panafax UF790 fax machine? We're having problems with our fax after converting to an IP Telephony system.
Yes, it is in the technician's service menu, however, that will not cure your problems with a DIGITAL phone system.
ALL fax machines are ANALOG.
Sep 10, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Fax machine
Function 71
set
enter date with number pad
enter military time
set
stop
Nov 13, 2008 | Panasonic Office Equipment & Supplies
How to set an old fax machine
function 7,1 set for date & time, press set after entry
function 7, 4 set then parameter 12 for confirmation report, set to on.
Apr 16, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
Change Date/Time on Canon Fax L350
Left the flap on the right hand side of the fax machine.
Select Data registration
use the down arrow
1. Data registration
SET
1. User Settings
SET
1. Date & Time
SET
Enter date or time
SET
Nov 16, 2007 | Canon FAX-L350 Plain Paper Laser
Time and date
This looks like the UK version of the Canon 730. Look in the manual but as I recall, Press data registration and then set scroll down to time settings and press set and scroll down to time and date and set. Enter new time and date and set. Press stop to goto standby
Apr 26, 2007 | Canon FAX-L1000 Plain Paper Laser
Time on fax machine
Lift up panels. Press data registration press set. scroll down to user data and press set. scroll down to time and date and press set. Enter time and date and press set. Press stop to exit
Mar 02, 2007 | Canon LaserClass 2060 Fax
Panasonic Panafax UF-790 Plain Paper Laser Fax Logo
64 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
