Question about Sanyo Audio Players & Recorders
What does un disc mean on sanyo stereo - Sanyo Audio Players & Recorders
Will not work.display comes on , when un-plugged and plugged in , can hear it coming on but soon winds down.
lens cleaning disc....... or laser needs trimming (the light goes weak and needs turning up)
Jun 23, 2014 | Sanyo DVW-6000 DVD Player/VCR
NECESITO EL CODIGO DE UN TELEVISOR SANYO CON UN CONTROL REMOTO DE JVC
These are the codes for Sanyo TV: 0049 0097 0110 0004 0268 0012 0108 0180
Aug 19, 2012 | RCA Universal Remote Control
Sanyo dc-ms6u hifi shows no disc??
the OPU( is the laser beam) can be faulty, you must go to the repair shop TV, for fix it.
God bless you
Jun 19, 2012 | Televison & Video
I have 2007 yaris the car stereo see error 1
Hi, ERR1 means dirty disc/ cannot read disc. You should use a cleaner CD to clean the stereo before use again...
May 29, 2011 | 2007 Toyota Yaris
Hi, I want to know if it's possible to connect my computer to the Sanyo-dvd (DWM-2500) loudspeakers. If it's possible, could you tell me how? I can't find it anywhere. Thank you very much!
In stereo, yes. At a minimum your PC should have a headphone output and/or a rear-panel stereo speaker output (usually 1/8" green), which is essentially the same. Get into the audio controls and set whichever you use to be Large Stereo speakers.
Get an adapter for the 1/8"-stereo-to-RCA-cable pair and attach it to the only analog audio input on the Sanyo.
Dec 13, 2010 | Sanyo DWM-2500 System
My player reads "bad disc" when i start it up with a disc inside. What does this mean?
It means that the laser head is no longer getting a good signal - the lens is dirty and you must clean it by using a cleaning disk : $10 at Walmart.
If the clean doesn't help then the dust has been baked on the lens - in that case you must replace the entire laser head. Find one in un its sold for parts, or discarded ones. If you can't find a replacement head then the un it is dead.
Sep 30, 2010 | Polaroid Portable DVD Player PDM-0822BD
Tengo un tv sanyo avm 141m q no enciende y me tiene loco.agradeceria ayuda
Tengo un tv sanyo modelo avm-141m necesito el diagrama electronico, tienen mala recepcion, selector sospechoso,
gracias
Aug 12, 2010 | Sanyo Televison & Video
I have a sanyo dvd player dwm-395. how do i unlock it w/o remot
For the DVM-390 model, I believe this solution should work on the DVM-395 model - Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
Dec 24, 2008 | Sanyo DWM-390 DVD Player
165 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
