Turn the washer on, no water starts, but can hear
Turn the washer on, the water does not start, but can hear a hum.
    Problem Solver:
  • 8 Answers
Your pump is blocked locate it and undo 3 bilts on cover and you should see the blockage inside
Posted on Dec 11, 2009
Samsung front load washer will turn on but will not let water in to start wash cycle.
the humming sound is the coil for the solenoid that activates the water valve
have an technician replace it or if you are not using hot water ,change the hoses at the taps and use a hot water setting
Mar 25, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Have a whirlpool washer that now hums when I turn the cycle on, no water just a hum
I had a similar problem - had to get a technician out - there was a valve at the back of the machine that allows the machine to fill. It had split (apparently its a common problem? there are separate valves for hot and cold water, so I'm not sure if using a different cycle choice (ie cold only), may let the machine fill?). 10 minute fix job
Jul 14, 2012 | Whirlpool Washing Machines
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | Kenmore 43142 Front Load Washer
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
Washing machine hums
your washer hums but does not start. do you have the water turned on? mine did the same thing and i forgot to turn on the water, the hum sound was the pump
Jan 15, 2012 | Kenmore HE2 Plus Front Load Washer
When i start my Indesit washing machine,i only hear a humming sound and nothing more.. it will just not begin to work.. please help me.
The humming sound you can hear is probably the water inlet valve energising but not letting the water in.
Check that the water is on to the washer, to be certain it is remove the inlet hose, and see if there is water present, if there is, then the valve itself could be faulty.
Hope this helps.
Jan 13, 2010 | Indesit W 123 Front Load Washer
Washer doesn't do anything. We start the cycle
Nothing will happen untill the water comes in. Check the water inlet SCREENS fer clogs
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 31, 2009 | Washing Machines
I have a maytag washer (model -dependable care) and when we start the wash the motor just hums, the water does not fill, if we move the timer switch to rinse the motor engages and the unit works entire the...
Check your fill tubes remove the hoses and see if the filters are plugged, you are not hearing the motor humming. You are hearing the watervalve humming, the motor will not start until the tube is full of water.
Jul 16, 2009 | Maytag MDB6650A Built-in Dishwasher
Moved to new home hooked everything up washer will not fill
ther's something wrong with your water supply to the washer the humming noise is the solenoid on water valve working check water taps to make sure there is water there and hoses are not kinked
Jun 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washer will not agitate or spin
it looks to me u need a new motor as the one u have is burned out...this is the humming u hear....contents insurance will pay for new motor if u have one
Apr 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
