Question about Garden
What are the factory jet settings - idle, low speed and high speed for the Poulan Pro 335? (number if turns out) It was running fine, but suddenly wouldn't keep running. I cleaned the air filter, replaced the plug, put fresh gas in it. Then it started, ran fine, but idled too fast. So, I adjusted the idle speed. Bif mistake. Now it won't keep running. It starts right up when choked, and runs for just a few seconds and dies. Then starts right up, unchoked, runs for a few seconds, and dies. I want the jet settings so I can have somewhere to start. Help!
5 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: My echo cs440 all of a sudden stopped running at
That is where I would go. Maybe carb clean or kit if it is a sudden change.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 01, 2010
mark24354
  • 776 Answers
SOURCE: I have a poulan pro pp4620avhd chainsaw. I can get
The best thing you can do to these engines it take them completely apart - take piston out and everything. Believe it or not, my 12-year-old son was able to do it - very few parts in these little 2-stroke engines. He polished the carbon off of the piston with a drummel tool and cleaned everything with carb-cleaner. Put it back together and it ran like a champ. Still does. It was a great learning experience for him too. The worst that can happen is you have a bunch of parts that you will throw away.
Posted on Mar 19, 2010
  • 4088 Answers
Check the fuel filter and muffler for plugging. Check the fuel lines for condition. Check the carburetor fasteners for tightness. If the saw has a lot of hours, remove the lower section of the carburetor and check the condition of the diaphragm--it should not be hard/cracked. If everything seems to check out ok, Turn both jet screws CW to stops (lightly), then CCW each 1-1/2 turns. The engine should start and run--allow the engine to warm up. Pull the throttle full on and adjust H needle CW til the engine speeds up, but still 4-strokes. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Let idle and adjust L CW so that the engine runs fairly well, but allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Posted on May 14, 2010
  • 1015 Answers
SOURCE: Hi, I just cleaned my
The fuel pick up or filter should be changed every year but if your saw will start and run good but just not idle then adjust the screw marked T counterclockwise slowly until chain starts to rotate without you depressing the throttle.At that point back it off about 1/16 of a turn until saw will idle but chain doesn't move.Thank you. P.S. If you want to you can go back to factory setting by turning H & L fully closed then open 1 to 1 1/4 turn and very slowly adjust for smoothest operation. Do not adjust H anymore then minimum off factory to avoid engine damage.
If you need further help I would suggest you have a trained tech.service it. Good luck.
Posted on Feb 14, 2011
How to adj the crab on a poulan chainsaw
if the engine is in good shape..screw in both carb jets adjusting screws till they seat lightly, then back them out 1 1/2 turns, srew in the throttle adj screw a turn and start the motor,,warning if the chain is on make sure the blade isnt likely to touch anything when the engine starts as you will have to have the brake off to get started and adjusted. With the engine running, adjust the throttle srew until it is idling just above shutting off speed, then adjust the "L" low speed jet to get the best idling speed without srewing it in much, reset the throttle srew, then , while trying to accelerate suddenly each time, open the Low jet a little at a time until the machine accelerates smoothly without hesitation. Reset the throttle srew to a position that the chain stops running at idle and check again that the acceleration is without hesitation ( usually with "L" jet about 1/4 turn out more than best idling). The high "H" jet can now be set to give the best power while cutting a block of wood.
Jun 29, 2014 | Poulan Garden
How many turns out is the factory setting on the high and low needles
Hi stanw71
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Oct 13, 2012 | Husqvarna 128LD 17" Gas Trimmer
Stihl FS 80 carburetor settings for high and low screws
Hi F Del
Bud
Oct 10, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
Adjust carb on poulan pro backpack blower
Hi randal book..
Bud
Sep 16, 2012 | Garden
FUEL MIXTURE SCREWS BEEN ADJUSTED IMPROPERLY. WHAT IS PROPER HIGH -LOW CARB SETTINGS FOR 40CC POULAN CHAIN SAW
Make sure the air cleaner is not plugged. Turn both jet screws CW to stops (lightly), then back each out 1-1/2 turns CCW. This is a basic setting and should allow the engine to start and run. When the engine is warmed up, pull the throttle full on and adjust H jet needle CW until the engine starts to speed up, but still 4-stroking. Correct adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Release the throttle and allow to idle. Turn the L jet needle CW until the engine idles fairly well, but the engine should 'follow the throttle'. It will tend to 'gasp' when pulling the throttle if you have gone too far. Idle speed screw should be set so that the chain doesn't try to turn, but the engine continues to idle. Hope this helps!
Jan 04, 2011 | Poulan Pro Chain Saw 46cc 20"
How do I adjust the carburetor on a Poulan 38cc chainsaw? Someone has messed with the low and high adjustment
Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Be sure to check the fuel filter, air cleaner, and muffler for plugging. Start the engine and allow to warm up--pull the throttle full on and adjust H jet needle CW until the engine starts to speed up, but still 4-stroking. Proper adjustment is reached when the engine 4-strokes at speed, but immediately 2-strokes when cutting. Release the throttle and adjust L jet needle CW until the engine idles fairly well, but will allow the engine to 'follow the throttle'. Set the idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
Jul 08, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan stalls out
on the side of the carb you should find two screws, one for the low speed jet nd one for he high speed jet. Turning the low speed jet only about a 1/4 turn at a time, adjust it in or out until it idles smoothly. Go to arboristsite.com, chainsaw and do a search on tuning for more complete info.
Jun 09, 2010 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
My chainsaw chain, moves even when the engine is at idle. the chain moves at quite a rate. what is the cause of this problem
Three choices
  • Your idle is set to high
  • or your low speed jet is set to high
  • Your chain is really loose
Mar 08, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain saw will idle, but not run at full throtle
First, check the air filter and clean it well. Then make sure the spark plug is clean and gapped properly.
Then prime, start it up, and allow it to idle, even using the trigger to make it fast idle if you can. Using a small thin screwdiver, turn the high speed idle screw on the carb in small increments to the right, kepping the speed up on the trhrottle.
The idea is to screw it out until it sputters, then screw it a half turn back in. If it doesn't smooth out when turning it to the right, try going to the left.
Afterwards you may find it doesn't run at low throttle well. If not, try the same thing starting to turn left until it smooths out. If it doesn't, screw to the right. Again, the idea is to go until it sounds rough, then back off a half turn.
You should be able to adjust it to the point where you can open the throttle all the way with smooth sure throttle increase.
Nov 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
