Printer says "Remove paper jam"
I have a Samsung SF360 printer. When I make a copy the original goes through and exits at the bottom, however the printer still runs for about 20 seconds after the paper comes out. It then says, "Remove paper jam". This happens with every copy.
Thank You
Vincent
bus.zone@worldonline.co.za
Check that the paper tray is set to match the paper your printing - look also in the printer driver settings for the correct size. A4, Letter etc.. If that did not fix it make sure the paper take-up roller isnt worn.
Posted on Jan 20, 2008
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
I REMOVE THE JAMMED COPY. PRINTER STARTS AGAIN AND JAMS UP AGAIN ON THE VERY NEXT COPY. COPY SEEMS TO BE MADE BUT CAN'T GET OUT OF THE EXIT
Jam may not be completely cleared or paper is not suitable for your printer.
You can find your User Guide, an Educational Guide on the paper which is compatible with your printer and updated Drivers here:
http://my.okidata.com/PP-B4350.nsf?opendatabase
In the Troubleshooting section of the User Guide (page 74 of the English version) there is a section on dealing with Paper Jams. Make sure you have cleared all areas and that your paper is compatible.
Trust this is helpful. Please vote.
Dec 25, 2010 | OKI B4350 Laser Printer
My Samsung CLP-300 is registering an exit jam, but there is no jam. I am wondering if there is a possible sensor at the paper exit that could be bad.
Hi there ok Yes there is a sensor
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Samsung CLP 300 Laser Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
When we put paper in the printer it goes cricked
Lexmark printer have paper roller problem take printer for once service
Jul 25, 2009 | Lexmark X1270 All-In-One InkJet Printer
Samsung CLP-315
paper exit sensor faulty,common problem with this printers.
Jun 08, 2009 | Samsung CLP 300 Laser Printer
Scorching paper
fuser exit rollers faulty
Jun 03, 2009 | Samsung CLP 300 Laser Printer
Paper jam at exit
The rollers at the exit area are worn out. They can be changed, in the mean time you can use something like sand paper to rub across the rollers to take the smoothness out of them. That will help them get a grip on the paper as it is exiting.
Jun 02, 2009 | Samsung CLP 300 Laser Printer
Paper Jam at exit
This happened with an old HP Laserjet 1100A of mine.
I had apparently dropped a screw in the paper-out slot and it was jamming the paper on just one spot.
As you know, the entire sheet is connected, so It is most likely a similar situation in which a previous jam has left a small wad of paper under one of the rollers, and this is preventing the paper from exiting the slot.
Best bet, print something and see where the paper is scrunching up. This is most likely the roller that has the paper stuck under it. Remove the toner block and blast some compressed air into the spot the jam is most likely originating and see if anything else flys out.
Also, if that does not work, you might try manually rotating the rollers backwards, which will often eject the lodged paper chunk.
Note- Please be careful inside the printer! Do not touch the bright green drum, or anything that dosen't look like it is rubber and rolls paper around!
It is very easy to mess things up in there ;)
Sep 28, 2008 | Samsung CLP 300 Laser Printer
544 people viewed this question
k24674
jasbo
jasbo
