Question about Kitchen Appliances - Others
Hello I have a Hadewe Chronus 0558 drill, but it
Hello I have a Hadewe Chronus 0558 drill, but it came with the wrong instructions. Well despite changing the dustbag it keeps telling me it needs maintenance?? Message on/off etc. I have no idea how to let it know I have done what it requires. What other filter is there to change? Please help.
Thank you so much
Katrina Waller of Compleet Feet Alton Hants
SOURCE: Maintenance Required light is on before i need oil change on my 2007 Rav4
I just did this procedure 5 mins ago on my 2007 RAV....some procedures state to do it from the ODO position but that will not work....use the procedure below.
Set odometer to Trip A
Turn the key off
press and hold the ODO button.
Turn key to ON
Continue holding button while the light goes through the series of the ----countdown and then flashes 0000. Release the button and turn key to OFF.
Thats it!
Posted on Jul 14, 2008
  • 1861 Answers
SOURCE: Remove Oil maintenance required message on 2008 Toyota Highlander
This is the reset proceedure for a 2008 Highlander with a key-type ignition:
Turn the key ON, do not start the engine.
Look at the odometer, and verify that it displays "TRIP A". If it is on "ODO" or "Trip B", press the black stick next to the odometer to read "TRIP A".
Turn the key OFF.
Press in, and HOLD the black trip meter reset button, hold it IN.
DO not release it.
Observe the Odometer display. You will see 5 dashes, then 4, then 3, then 2, then 1 dash, and finally, 5 zeros. Then, whatever number that was displayed on "TRIP A" will be re-displayed..
Now release the black trip meter reset stick.
This completes the reset procedure, and it will be back on in 5,000 miles, to remind you of you next oil change.
Hope this helps! Thanks for choosing FixYa!
Posted on Nov 17, 2008
SOURCE: Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
Posted on Mar 25, 2009
Molson02536
  • 3854 Answers
SOURCE: How 2 turn off "oil change required" lite
Ford Explorer, Mercury Mountaineer, 2002-06
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the SET UP control to access the System Check mode. Press and release the RESET button to display “OIL LIFE % HOLD RESET NEW” is displayed. Press and hold the RESET button for 2 seconds until “IF NEW OIL HOLD RESET” is displayed. Press and hold RESET button until “OIL LIFE SET TO 100%” is displayed.
Ford Five Hundred, Freestyle, Mercury Montego 2005-06 Tap the ODO/TRIP button to toggle the display between the odometer and trip odometer. Tap on the ODOiTRIP button again to toggle the display between the trip odometer and OIL LIFE % display. Press and hold the ODO/IRIP button for 2 seconds or more to display OIL LIFE 100%. Your oil life in now reset.
Good luck and print this and keep it in the glove box. Keep me posted if you have any other questions
Posted on Nov 04, 2009
greg_margo
  • 1959 Answers
SOURCE: How do I reset the maintenance required message on
With ignition off, press and hold "SELECT" and "RESET" buttons on dash and turn ignition to the "ON" position. Continue to hold until lamp resets.
Posted on Dec 15, 2009
Set up instructions for makita aquamax
Hello, GO to this website for manuals and setup instructions: Makita Authorized Factory Service Centers
Jun 03, 2014 | Drills
My spindle slide out of the drill press. I remove spindle to clean , what did I do wrong.?
Please look at this site:
http://www.ebay.com/itm/DELTA-MILWAUKEE-14-Drill-Press-DP-220-Instructions-Parts-Manual-0239-/310388408599
This site has pictures that might help:
http://www.ebay.com/sch/sis.html?_kw=Vintage+Delta+14%22+Drill+Press+DP220+%22Triple+Duty%22+Bench+Model+Tilt+Table
Jan 23, 2013 | Delta Woodworking Vintage Delta Dp 220 14"...
Owners manual for Skil 3320-02 120-Volt 10-Inch Drill Press
A drill press is an important device for each woodworker's store. Despite the fact that woodworkers can be able to perform a number of the drill press's functions with other tools, nearly all of them discover that these features are simpler and quicker to perform with a drill press.
more details about the Skil drill press go to the link Best Drill Press 2018
Jun 06, 2012 | Skil 3320-02 10-in Drill Press with Laser
Batteries wont charge
battery pack has a thermal cut out that could happen, or one batteries is open circuit Re: Jeff
Apr 11, 2012 | Drills
Had the Dewalt DC988 transmission fall apart on me, and despite my best efforts, can't get it back together. Does anyone know of any diagrams I could follow or advice? Thanks, Tom.
Go to servicenet.dewalt.com and enter your model number in the search window on the left where it say's find parts. You'll see a list of parts by description and link to an exploded view.
Oct 01, 2011 | Dewalt 18 Volt Compact Drill Kit
Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Oct 10, 2009 | Makita Drills
Kitchen Appliances - Others Logo
77 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
