Question about Janome Memory Craft 5700
When sewing elastic type material it keeps knoting
  • 96 Answers
You may need to use a certain type of thread for jersey knits and stretch fabrics also your machine should have a setting for stretch stitches to allow for smoother sewing
Posted on Dec 14, 2009
We have lost the extra manual for the necchi 6022 sewing machine. It had the instructions on how to create designs and what settings to use when using the serger foot in stretching/elastic material. I...
I'm a bit confused, this isn't a serger machine as far as I can see. So do you mean an overcasting foot where you sew a XXXXX type stitch along the edge of the fabric? The overcasting foot just helps you to line up the fabric edge and sew over it neatly.
if you go to this page http://www.sewingpartsonline.com/necchi-6022-sewing-machine-parts.aspx
there is an instruction manual for sale.
http://sewmamasew.com/blog2/2009/06/feet-feet-feet/ is also a great resouce on sewing machine feet with good photos of what they are used for.
Here is a video of overcasting foot in action http://www.sewingmachine-sales.co.uk/sewing_machine_info/video/34/adjustable-overcast-foot.html
If you are wanting to sew knit fabric then you just need to use a small zig zag stitch and a ball point needle to put elasticity into the seam. Or your model may have a stretch stitch, where the fabric is moved forwards and backwards during the stitch formation to add some elasticity.
Sewing elastic stretched onto fabric is a bit different with a SM, can be fiddly and hard to keep everything lined up nicely and stretched. Some machines have a little device which clips onto the needle plate in front of the needle that you can feed elastic through and tighten it to tension it, then just use a three step zig zag stitch to seam over this onto your fabric. But I don't know if Necchi has such a thing, your needle plate would need holes in front for it to clip into. Elna had these on their swiss machines in the 80's but haven't seen a similar device for a while.
Hope I've answered your question and not completely misunderstood your problem. Purchasing a manual is often the best way forward when a machine is unfamilar. Or www.sewing.about.com is great resource.
Jun 06, 2011 | Necchi 6022 Sewing Machine
Thread is knoting at the bottom and bursting. The machine is only sewing with elastic thread. When I try sewing with straight stitch or zig zag it will knot at the bottom and burst.
Maybe you need to adjust your tension and double check your threading. I have never (in 50 years) sewed with elastic thread but I think a call to Singer customer service at 1-800-4singer may be in order.
Dec 28, 2010 | Brother XL-3510 Mechanical Sewing Machine
Bobbin keeps jaming and knoting
Go to either Singerco.com website or brother-usa.com
and look for their solutions for free or call Janome, phone number should be in your manual.
Aug 27, 2010 | Janome Jem Gold 660 Sewing Machine
Stitching is loose and knoting up on the underside of the material - why?
1.check to make sure it's threaded correctly, sometimes the thread come off the thread take up lever on my mechanical sewing machine.
2.check the needle to see if it's bent
3.check to see if the needle is in backward
4.check the thread tension
5.check the bobbin to see if it's warped-i've gottin ahold of several of them
Jul 29, 2010 | New Home Sewing Machines
When sewing with shirring elastic on bobbin the material does not gather the machine sews great any other time model no is bm-2600
my friend and i sat at the machine to see what was happening
the 1st thing wrong the plastic bobbin was the wrong size and the bobbin was not threading through the tension spring as the elastic was to thick
Jan 05, 2010 | Brother LS2020 Sewing Machine
Brother XL2230 Elastic Overlock function not working properly
First of all check your needle size and utility, for the tension machine it must be the same on top and bottom example pull the top thread and the lower thread they must be the same.
When sticthing the elastic you must devide the amount of elastic versus the fabric : dise the amount before stiching
Hope this will help
Good day
Feb 16, 2009 | Brother XL-2230 Mechanical Sewing Machine
The thread is knoting underneath when sewing
It sounds like you maybe using the wrong needle size for the material you are sewing, or perhaps it is the thread. I've found that not all threads are created equal and it may be too fine/heavy for the needle gauge your using.
Check out this site. All the Q&A answers in simple language, as well as a GREAT cust. support staff. (its a Brother after all!)
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/model_top/HomeSewingMachine/hf_ls1217eus.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus
I hope this was helpful. Good luck and...
Happy sewing!
Jan 14, 2009 | Brother LS-1217 Mechanical Sewing Machine
Can see alot of thread at the seam
Sounds like your needle threads are not tight enough.
Do some samples using different colored threads, if necessary, to see which needle thread is not doing the job. Then tighten in increments till you get the right tension settings.
It helps if you make notes of the correct settings on that material for the next time. Start a sample notebook, for the different materials you might use with tension settings for each, and if you do any fancy stuff with your serger, like pintucking, puffing, elastic application, ruffling and such.
Aug 12, 2008 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
90 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
