I have an Empire dv 210 gas heaterand pilot wont stay lit
I have an Empire dv 210 gas heater and as soon as I let up on the pilot button the flame goes out. I had it started for a few hours after many ,many attempts and then it went out again.
    Scholar:
  • 124 Answers
The thermocouple has went bad Here is a link that describes what a thermocouple is how to replace it and has instructional videos
http://www.ehow.com/way_5185498_thermocouple-replacement-procedures.html
I could try to describe the procedure. But the link is more detailed and the videos are really good.
Hope this helps
Please leave feedback
Posted on Dec 11, 2009
    Problem Solver:
  • 18 Answers
Yup, i agree too. bad themo
Posted on Nov 08, 2011
New kozy world natural gas heater. Pilot light wont stay lit snd heater flame wont stay lit.
Are you holding down the pilot light button long enough for the heat sensor probe to get hot and turn on the gas valve? It takes up to 3 minutes
Nov 20, 2016 | World Heating & Cooling
I have an empire dv-60-18pp that the pilot won't stay lit...why?
Thermocouple problem. make sure it is in the flame. make sure it is not covered with patina. if it still wont work replace thermocouple.
Jan 30, 2015 | Empire Heating & Cooling
I have a Empire DV210 wall mount vented furnace. The pilot light is very hard to start and has a very small flame not touching the thermopile. The flame is blue but very small. I can not get the primary...
The pilot ofifice probably has a bit of dirt in it...to get it out you will need to take the pilot apart and clean it out...this can be fairly difficult on those heaters and getting it back together can be a pain...pay attention as you take it apart...blow our the tip with canned air like you would use to clean your keyboard...
Then reassemble...
Sometimes the "hood" or the cover over the flame will bend up over time and you will also have to bend it down a bit to get the pilot flame onto the thermocouple...make sure the thermocouple is also pushed all the way up in the holder...
heatman101
Mar 18, 2011 | Empire DV-215 Direct Vent Natural Gas...
I have an Empire gas heater. It does not stay lit. It will go out after about 30 minutes to two hours. When we first started having this problem if you set it where it wasn't completely level it would stay...
Look at your thermocouple. Is it glowing red from being heated by the pilot flame? Is the pilot flame blue or yellow? You may have a dirty pilot orifice that is not heating your thermocouple enough to keep it lit after the burner cycles off. A yellow flame will eventually burn the tip of the thermocouple, which causes more frequent problems and eventually it will not work at all. If you have a can of compressed air with attached straw, use it to blow out the pilot orifice (with the gas off) where the pilot flame usually burns. Then examine the tip of the thermocouple and see if it is still round and smooth. Jagged or irregular tips mean it should be replaced. A blue pilot flame and a new thermocouple should do it. Hope that fixes it for you. Douglas
Jan 04, 2011 | Heating & Cooling
Pilot wont stay lit and weak flame
Tap pilot head to knock off any built up corrosion and rust and flame will get better and keep pilot lit
Nov 25, 2010 | Empire DV-35 Heater
Will not stay lit. Heater will light and, heat but goes out and will not come on by itself.
Does it go out immediately or pretty soon after it lights? That sounds like a problem with the thermocouple or whatever it uses to detect the flame. May need to be replaced or cleaned.
Jul 19, 2010 | Empire DV-215 Direct Vent Natural Gas...
Pilot wont stay lit when i release push down button on gas valve
Are you certain you are connecting the generator to the correct terminals? Is the pilot head partially blocked not allowing the flame to reach the generator even though the pilot is lit? Can you read the millivolts on the generator leads? Is the reading 400mV or higher? I assume it will be with a new generator but if it is not then the flame is not across the generator as it should be. If it is, be certain you are connecting the two leads properly and in the correct order. The generator has polarity so it needs to be connected to the valve properly. The tag up inside the heater should give you the correct locations for the white and red wires on the valve.
May 29, 2010 | Hayward 150000 BTU Millivolt Natural Gas...
I HAVE A DESA LP VENTLESS FIREPLACE AND THE PILOT WILL NOT STAY LIT
the heater makes use of a millivolt generator which generates a small dc voltage (500-750mv) that is applied to the pilot valve of your main gas valve. when you light your pilot, the flame bathes the generator with a flame. after a delay you release the pilot button. if the generator is working, the pilot valve will stay lit. if the generator is not working the flame will go out as soon as you release the pilot button. change the generator.
Oct 13, 2009 | Desa International Heating & Cooling
Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Oct 07, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Empire DV-215 Low Flame Issue
Either a restriction in the gas train, low gas pressure or a bad gas valve. Check the pressure on the gas line when on pilot and again when the burners are running. Depending upon what type of gas it runs on, you should have at least 4" W.C. if Natural Gas and 10" W.C. if Propane. If gas pressures test good and all valves are open, you are looking at replacing the gas valve.
Dec 08, 2007 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
257 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
