Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Aquarius WD62 Went to switch on our washing machine and it blew the main RCD and now does not work, any ideas
  • Chaps32 May 11, 2008
    My WD62 trips the RCD after its finished a washing programme, all is well until the next wash when it happens again
    Scholar:
  • 90 Answers
Did it pop the main breaker or something on the machine??? If on the machine not sure. If the main breaker to the machine, there must be wires or something shorted out in the machine...Either way if it is not obvious, I would suggest letting someone familiar with electric help you directly trace down the short.... With more detail and your knowledge of voltmeter use I can help you. Look for bad insulation on the main wires..
Posted on Feb 10, 2008
Hi, I have a Hotpoint Aquarius 7kg WDL520 washing machine. I have just went to open the door to hang out a wash I did earlier. The door is locked and no power seems to be in the washing machine as...
Does it have a separate drawer for the detergent and softener? sometimes opening that will unlock the door. It sounds like it was overloaded and blew an interior circut
Oct 21, 2010 | Washing Machines
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Loud noise when spin drying, rumbling sound, sounds like concorde taking off! Hotpoint Aquarius 1200 washer dryer WD62
Remove rear panel of washer, and remove drive belt.
Spin the drum by hand, and if it feels rough, or is noisy, then the main drum bearings have failed, quite a big job to do.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Aquarius wd62 front drawer leaks
I had this problem and solved it by just leaving the draw sticking out a little bit! Now there are no leaks!
Feb 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius WD640
got the same problem, engineer came out thinks motor will need replacing approx £180 plus fitting
Apr 05, 2008 | Hotpoint Aquarius WD640 Front Load...
My Hotpoint Aqaurius WD62 is filling but wont drain or spin
try replacing the interlock first then check the the continuity in the interlock lead
Mar 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Wd61
What ha happend is the door interlock shorted and blew the rcd. However in doing so it al blew a triac on the timer..
This is very easy to repair if you know how to get to the timer... but you also have to replace the door inter lock...
Solder a bit of wire between the connections on the timer...
If you follow the neutral wire back fro mthe door interlock upto the timer then you will see what i mean by it blowing the triac...
Jan 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1000 WM62 motor problem?
hotpoint aquarius 1000 if motor is connected (plastic plug in socket) RCD earth trip trips in main board when washer is switched on, trips as soon as water starts to fill.
Oct 16, 2007 | Washing Machines
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Earth Fault
IM GUESSING THAT YOU GOT A LEAKY GASKET THATS SPRAYING WATER ONTO YOUR DOOR INTERLOCK SWITCH CHECK TO SSE IF YOU AHVE ANY RIPS OR TEAR IN THE GASKET. DOOR INTERLOCK WOULD BE WORTH CHANGING AS THEY DONT COST MUCH.
Jul 24, 2006 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
88 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
