Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Brush attachment stops spinning
Spinning brush attachment stops spinning. This is the 3rd brush attachment I have had to buy, why does it keep breaking.
  • 85 Answers
Does the pin break or the turbine freeze
Posted on Dec 15, 2009
I have a spin brush Conair infiniti pro and the brush stopped spinning. How do I fix it?
Replace the brush bar you'll have new brush bar better clean than old brush with new bearing which aren't available or worth the bother fitting, ps keep the filters clean makes a real difference to sucking power.
Oct 22, 2017 | Conair Vacuums
Why is my Shark nv500 vaccum carpet brush is not spinning?
I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
Aug 01, 2014 | Shark Rotator Professional Lift-Away...
Dyson DC23 canister vacuum turbine head attachment stops spinning.
bearing inside the turbine has failed. cant be repaired you will need to buy a new one your local vac centre will have one
May 17, 2017 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
Why does the beater brush belt keep breaking?
The belt on this model series will break if the roller stops spinning or spins with high amount of resistance. Remove the brush roller and check that it will spin freely, if it does not it would need repair or replacement.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 21, 2014 | Tornado CK 14/1 QD Vacuum
Dyson dc04 belt breaking
Is there something sticky stopping the brush from spinning freely will make the belt get hot and burn out
Jul 10, 2013 | Vacuums
My spin brushes are not spinning. Took out the spin brush attachment - the main port that the attachment plugs into is not spinning. Is this repairable?
Sometimes it can be the inside rod of the brush barrel has resonated hair build up preventing the, what appears to be clean, brush. Check to see if either end of your brush wheels has a nut or can unscrew to clean inside it.
Sep 01, 2011 | Hoover Vacuums
Beater bar rotating but now making really loud almost buzzing sound???
It is probably a bad belt.That model uses a geared belt and you possibly have a few teeth missing on the belt.It could also be a bad brush or bad motor but less likley.Take the cover off of the power nozzle and inspect the belt.Disconnect it and look at it for missing teelh or a bad spot where they look different than the rest if this is the problem you can stop reading and just go buy a belt.Spin the brush by hand it should give very little resistance without a belt attached.If it spins freely then inspect the ends for a bad bearing.Check the plastic end caps for melting.If they look ok then try moving the brush back and forth slightly to see if the bearing has come apart.If the brush is spinning free and the ends are not showing any movement other than spinning around then inspect the area where the belt rides and make sure it is free of debris like hair and string.Finally plug in the machine with the power nozzle attached and the brush disconected and cover still off and listen to the motor in the power nozzle.If it still makes the noise it's the motor www.sewvac.com
Jan 28, 2011 | Kenmore 25512/ 25513 Progressive Canister...
The brushes on my kirby are not spinning. What could i do to fix this?
Sounds like a broken belt. Take it to service store or buy a belt and replace it yourself. It's actually more simple than you think. Good luck! Did you get a funny burning smell when the brushes stopped spinning?
Jul 26, 2009 | Vacuums
My brush won't spin, and won't **** well
u need a new band inside they break and it stops the brushes spinning
Jul 13, 2009 | Kirby G6 Bagged Upright Vacuum
The spinning brush just stopped spinning. This vacuum is only a few months old. Please help!!!
Hello. The very common reason this happens is that the belt that drives the brush breaks. The fix is to get a new belt and install it. Do not get a generic belt, get an original equipment belt from a vacuum cleaner store.
Jun 20, 2009 | Vacuums
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
219 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
