Question about Microwave Ovens
How do I reset the clock on sharp model no. R242?
  • Microwave Ovens Master
  • 9,176 Answers
Normally you press Clock, then the numbers, then either Clock again or Start.
If that does not work, you can call Sharp USA at 1-800-BE-SHARP (1-800-237-4277) for assistance.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 27, 2008
6ya staff
SOURCE:
I cannot reset clock
Touch Timer/Clock pad and number 2 pad.
Enter the correct time of day by touching the numbers in sequence.
Touch Timer/Clock pad again.
Aug 15, 2015 | Sharp Carousel R530EST Microwave Oven
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    I have a sharp carousel microwave model r-120D. It is flashing all 8's like so 88:88 and i cant get it to reset or work at all. Can you help?
    usually does this after power outage. reset the clock. go to sharpusa.com and select PRODUCT DOWNLOADS under the CUSTOMER SUPPORT menu...select product not listed in drop down list, then enter R120PK in box....this should be the manual for your microwave
    Dec 10, 2010 | Sharp R-120D Microwave Oven
    Unable to set microwave clock
    sometimes the clock resets after unpluging for a short period. when you restart / power up note the time it starts at generally 12:00 miday good luck gbw
    Feb 07, 2010 | Sharp Microwave Ovens
    The lds panel say lock when i try to use the microwave oven how do i unlock it?
    If it has a "help" or "Custom Help" pad, the Child Lock may be on. If so, press the Help button and look through the options, if any.
    Otherwise, it may need a hard reset. Unplug the oven for a couple of minutes, then see if you can set the clock.
    On most Sharps, the sequence is:
    Clock > 2 > 3 > 0 > Clock
    or
    Clock > 2 > 3 > 0 > Start
    You may be able to download your owner's manual from Sharp's site.
    If it still won't work, you probably have a shorted keypad.
    NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
    So please reply back directly to me with your brand and full model number from the for free do-it-yourself tips and an estimate if required.
    William E. Miller
    [email protected]
    http://www.microwavedisplay.com
    Sep 26, 2009 | Sharp Microwave Ovens
    Cant set the clock
    hi
    In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
    Clock > time digits > Clock
    Clock > Clear > time digits > Clock
    Clock > time digits > Start
    If that doesn't work, please reply back with your brand and full model number.
    All the best and do rate this answer if u r satisfied.
    thankyou
    May 10, 2009 | Microwave Ovens
    I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
    May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
    Gert
    Aug 05, 2008 | Sharp Microwave Ovens
    I don't know how to use the defrost function on my microwave, model sharp-r242
    Hi - You can download the manual from the link underlined in blue below:
    moz-screenshot-1.jpgsharp-r242
    Please update the question & let us know if the information given was useful to you - Good Luck!
    Jul 31, 2008 | Sharp Microwave Ovens
    Setting the time on Sharp microovens.
    Normally it's
    Clock > time numbers > Clock
    or
    Clock > time numbers > Start
    Sometimes it's
    Clock > (1 or 2) > time numbers > Clock
    or
    Clock > (1 or 2) > time numbers > Start
    If this doesn't work, please reply back with your model number.
    Mar 08, 2008 | Microwave Ovens
    Microwave Ovens Logo
    122 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Marvin
    Marvin
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
