Question about Kenmore Elite Oasis 27052 Top Load Washer
F code on my washer
No matter what setting I have the washer on the cycle will start and then a few minutes later stop and give me a F error code what does this mean and how can I fix it?
  • Brad Brown May 11, 2010
    Is there a number after the F code? This is a common problem for this machine. Unplug it and plug it back in and let me know
    Problem Solver:
  • 13 Answers
Check the lid switch
Posted on Dec 17, 2009
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
02 f error code
F/02 code appears because :---------Long DrainIf the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
to resolve this problem  :----------
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.----------------
  • rate the solution.
thanks.
Jan 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer problem
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
First, try to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, then proceed with the steps outlined in the link I provided for you.
This is one of the more "involved" error codes that you may need spend some time with. Although, it may NOT be a difficult repair, it still may require some diligence to figure out the cause. I would recommend checking your washer installation for a potential siphoning problem and then check the drain pump as these are the more common causes. If you require additional assistance, please let me know. I hope this helps you.
Jan 04, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer starts, runs a few seconds and stops,does it over and over
Sound like the internal overload on the motor may be going out .Thsi is usuaklly due to bad or worn bearings. If you know anything abotu electricity,take a voltage reading at the motor whe it is in the run cycle(when it stops) If you stil have have the 110Volts to the motor then the motor is bad and need to be replaced.If you do not then you wil have to look elsewhere for the problem.
Dec 14, 2008 | Amana NAV5800A Top Load Washer
Error code LE on LG Wm1815cs
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
"F" error code in WTW6600SG1 Cabrio Washer
I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
Jul 07, 2008 | Whirlpool WTW6600SW Top Load
turn the water supply on,, f/h is a fault occurring when ther is no incomig waterdetected
Apr 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Our machine was giving the HF code at 37 min after over filling with water. I unplugged the machine, popped the top (took the 3 torx screws off the back) pulled the small hose off the pressure switch sensor (round sensor on the upper back right of the machine) and blew it out just by mouth. It obviously cleared some junk. It works fine now. (also unplugged the 6 wires on the sensor, turned it around and blew on that and heard it clicking, so I knew that was ok.) Hope this helps someone.
Oct 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
123 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
