Question about Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit
N-80 vintage 1986 the striker does not return far enough to engage the next nail. If I turn the gun upside down and tap lightly on the head it will usually allow the striker to retract.There are no air leaks
    New Friend:
  • 109 Answers
You have lost compression on your piston o ring, instead of air pushing the piston back for the next nail its going around the piston , and the proof is that your piston will move with a simple tap. please replace all orings, because if one is worn the others arent far behind, if you dont replace all , at least replace the piston one and all the cylinder ones,,o rings kit are available at your nearest nail store or try toolpartsdirect.com plz rate this answer,,tks
Posted on Dec 11, 2009
My L key is stuck DOWN! How do i fix that ?
WD40 fixes everything. Turn it upside down and follow the L - Key from the top. Then follow it to the striker key. I can't remember if they have individual return springs. Been a long time :>)
Dec 28, 2015 | Smith Corona Office Equipment & Supplies
Senco frame pro 601 turns nail upside down with nail head going in wood first
The nails can turn over if you have the wrong angle or gauge nails in the tool. Make sure you are using the proper nails for your gun because they are not all the same.
Feb 19, 2015 | Senco Tools & Hardware - Others
My RN175 shoots you think it shot the nail, but when you move the gun to shoot the next nail the nail you just shot falls out the end of the gun. What could cause this?
The driver is coming down far enough to break the nail off the strip but not far enough to drive it in. This could be caused by any of the following:
- The driver is broken off and too short to drive the nail
- The driver is bent and doesn't travel all the way down
- The seal/o-ring on the piston is damaged and air is leaking past it
Any of the above will require you to remove the head and inspect the driver, piston and o-rings or have a service center check it out.
Mar 07, 2012 | Porter Cable RN175 Roofing Coil Nailer
I have a dewalt framing nailer that will operate with a max pressure of 120psi. I have been using it for 2 weeks with 100psi. Now the piston will not return after shooting the first nail, unless I adjust...
Your gun should work in the 90-120 psi range to get a consistant drive depth and with a few drops, 5-6 or a small squirt, of oil at the start of work and a few more in the afternoon if you are using it a lot. It is possible to use too much oil, if you over oil it and the bottom of the cylinder chamber gets full of oil or other gunk attracted to the oil it can get high enough to interfear with the return function. Also if you are using something other than pneumatic nail gun oil it is possible some o-rings were damaged. Either way you have to remove the head cap and check the internal o-rings for damage and clean out anything in the cylinder and head chamber.
Jan 21, 2012 | Dewalt D51823 Factory Reconditioned 2 inch...
Nailer will shoot a nail, but will not foward the next nail. Gun is new maybe 15 lbs of nails or so.
If the nail will not advance, easy test will determine problem. Open door and remove the nails. Lightly tap the nose of the gun against coiled rubber hose or soft wood with door open. If the driver falls to bottom, the piston oring needs to be replaced. The driver should stay at top of cylinder. Next pull back the feeder to rear position and check for tension. The feeder should spring back towards you when you push. Finally, the check paws on the door should return to extended positon when you push on them. Replace springs as needed. Connect air to gun and rapidly bump fire the gun against rubber. The feeder should move back and forward just as quickly as the driver moves. Good luck
Aug 25, 2011 | Hitachi NV45AB2 78Inch to 134Inch Roofing...
Using recommended 3 1/2" nails; cannot get the nailer to sink the nail all the way to the head. Depth is set to max and air pressure within recommended range of 70 to 120 p. s. i. g.
remove the nails and air hose. tap the gun lightly and does the driver fall down?? if so it needs new o rings and doesn't have enough seal to drive the nail. also look at the condition of the driver. FOLLOW CLOSELY, reconnect the gun and remove the nails pull back on the follower and using a piece of wood to activate the safety hold gun at an angle, weara safety glasses and depress and hold trigger to expose the driver, does it extend past the nose and LOOK DONT TOUCH to check the condition of the end. release the trigger. this should give you some ideas why. also recheck the nails for proper collation and head are they clipped or full round. Let me know and I will try and help further. READ closely before attempting the above ideas.
Aug 26, 2010 | Stanley Bostitch F21PL Nailer
Nail gun not firing nail
THe most likely causes of this are not enough air pressure (90 psi) or a nail is jammed in the front, causing the striker to stick down. Also, if it hasn't been oiled in a long time, that could cause it.
Nov 16, 2009 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
After each shot the nail gun jams
hi visit your supplier and ask for a overhaul kit once fitted your tool will be licke new
best of look ian
Mar 25, 2009 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
The nails aren't going in far enough using a air cleat nailer
I just finished 800 square feet of oak flooring with this nailer. You might have to increase the psi at the gun and make sure it gets a good square firm hit to set the nail. You can swing and hit the thing pretty hard, I hit it hard to set warped boards in place. I used 120 psi for best results, I tried 90 psi but had more misfires. The nail head only needs to set in far enough so the head is touching the tongue and so the next board will fit. The nail won't be buried into the tongue like you might think. If the occasional nail protrudes from the board you can use a nail set to drive the nail the rest of the way in, but I found that most of the nails didn't want to set by hand. I either clipped off the head with side cutters and folded over the remaining tab or did my best to set the nail if it wasn't long enough to clip. If it bends over really ugly, just carve a little wood from the groove lands on the next board to clear the nail stub. Removing the nails is difficult, it's best to let them be rather than risk damaging the flooring. Also, don't let the gun get down to the last nail. Sometimes if you try to fire the last nail on a strip it will twist and damage the flooring. Always keep a few nails in the gun just to be safe. Hope this helps.
Nov 23, 2008 | Porter Cable 2" Flooring Cleat Nailer...
Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit Logo
334 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Mike
Jay Finke
Jay Finke
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
