Question about Panasonic Lands Phones
Will the following phones be compatable to the KXT61610 system and are they analog and capable of handling 3 incoming phone lines: KXT 2335 KXT 2355
  • Panasonic Master
  • 2,460 Answers
Yes and no. The phones you mention are analog, but they are single line sets. The 61610 handles single line sets and you can access all 6 lines by dialing codes. If you can find Panasonic model 7030's, 7130's 7020's 7050's, they would be a much better product. You can even use 7730's and 7731's with some degree of success (backlighting eats a lot of power).
Any phone can access lines by dialing 8x codes or all lines by "9". You have to program (05, 06, 07 and 08 IIRC) the lines to the stations in system programming and you MUST HAVE one display set in Jack 01, ext 11, to do programming. A KX-T7030 is adequate.
Carl
Posted on Dec 14, 2009
How do I reprogram the speed dial numbers in my Panasonic KXT61610 phone system?
Try Googling (Panasonic)(KXT-61610)(manual) without parens.
Jan 23, 2018 | Lands Phones
How do i program the panasonic kxt-7731 so when a call is coming in i can just lift the handset to answer instead of pushing the co line
You have to do 2 things: Make it ring and turn on Line Preference-Incoming Ringing line. The first is done from SYSTEM programming in programs 408/409/410 for DAY/NIGHT/LUNCH. The second is defaulted to Ringing so if the phone rings, it's supposed to work. If you've changed it, then from your idle phone you press PROGRAM and dial 22 STORE. (21 is no preference and 23 plus a number is a specific line).
Carl
Apr 26, 2011 | Panasonic KX-T7731 Corded Phone
Hi I have a panasonic KX-T7730 and I need to connect it to my linksys PAP2T Device. but I haven't Voice Over It. can I use this device with KX-T7730?
The 7730 is a Panasonic Analog System phone. It plugs into a Key Service Unit and the line port plugs into the PAP2T device. Model numbers like KXT-A624/824 are examples.
Carl
Feb 18, 2011 | Panasonic KX-T7730 Corded Phone
Have a kxt-7453 and need to attach a heart monitor which needs an analog phone line. On the back of the kx-t7453 is an XDP jack to attach a fax machine. This would be the analog port; however, there is...
It depends on the system the phone is wired to. A TD-816 has modular plugs on the base cabinet, but uses an Amphenol cable for the expansion units, and a 1232 is all Amp. You need 4 wires to make it work. The quickest way to test is is to unplug the digital phone and plug a single line set into the same jack. If it works, then you need to do some system programming. If it doesn't some wiring.
The digital phone uses the outer paris of a 4-conductor jack, and the analog/XDP is on the inner pairs. We always use 2-pair jumper wire on TD systems, but some installers cheat and don't wire both pairs. You'll know if it works because the single line phone you plug into the jack alone will have the same extension number as the digital set.
If you have dial tone there, by default, when you plug in the digital set, the XDP has to be turned on in program 600 and there's a merge/unmerge comand. The XDP port is 100 more than the station (ie 103/203) and the code to merge/unmerge is 390 and 391 (I can't remember which, so look at the display as one merges (probably 1 and one doesn't 0)
You'll have to teach the device to dial "9" or an access code 81-88 to get a specific line or group.
Outside of that, it's not that bad to program.
Carl
Sep 18, 2010 | Panasonic KX T7436 Corded Phone KX-T7436
Call forwarding for NorStar m7310
You have to know how to get into programming, and it depends on the type of telephone lines you have... if you have regular analog lines, on a out bound call transfer there is going to be line degragation. Meaning that the outgoing call is not going to be of the best quality.
Secondly, you have to see how many telephone lines you have, if you have 3 analog trunks, with a call forwarding to a cell phone, you will be using up 2 lines... 1 incoming and 1 outgoing to your cell. This leaves 1 trunk for incoming or outgoing callers.
Jan 22, 2009 | NorStar M7310 Phone
Switchboard PABX purchase
If you need 8x30, you start with a minimum of TDA-100. It grows to 96 ports and you would start with 8 lines and 32 digital ports.
Your phones become KXT-7633's, not the 7731's. On this side of the pond, it costs about $20 more per phone, but you gain the use of 12 extra buttons, 3 line display, and more features.
Your Panasonic TDA/TDE dealer can guide you.
Carl
Jan 15, 2009 | Panasonic KX-T7730 Corded Phone
NEC Electra Professional Level I Upgrade
The NEC Electra Professional Level 1 has a maximum CO line capacity of 8 in any configuration. If you need more outside phone lines, you will need a different system. If you need to limit cost as much as possible, the cheapest avenue would be to upgrade to a used Electra Professional Level II. That way you can still use the same telephone instruments, but ALL cabinet hardware would be different. Also, you can only get to 8 outside lines if you have software level 3.00 or higher by using the COI-C(2A)-10 card. To verify which software version you have, I think you press FNC(3) on sta. 10 ( or the first station in the system). If that doesn't work, let me know, and we can access the system program to verify version number.
Dec 29, 2008 | NEC Electra Professional ETW-16DC-2
Panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Carl
Dec 05, 2008 | Panasonic KX-T7431 Corded Phone
Brother Intellifax 770 fax machine failure to receive faxes
I HAVE A BROTJERS 770 AMD ALL I DONE WAS GET A 2 SPACE TELE JACK AND PLUG IT INTO MY MODEM FROM COMCAST AND PLUG MY PHONE AND FAX INTO IT AND CAN RECEIVE AND SEND
Mar 24, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
How do I view caller ID?
The KX-T7731 is a proprietary system phone. You have a Panasonic phone system. Caller ID is transmitted between the first and second ring but the phone system itself is the only part that gets this information. The system has to be compatible for caller ID and it has to collect the caller ID data and send this information to your phone(s). Your phone can be used on many different Panasonic phone systems. The phone's part number does not help you. First thing you need to do is find out what system you have and if it has caller ID. The phone system part number should start with KXT like your phone.
Sep 17, 2007 | Panasonic KX-T7731 Corded Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
