Question about GE GSS25JFM Side by Side Refrigerator
I have a GE Fridge Model # GSS25JFMD WW. The compressor has stopped working completely. All other fans and lights seem to work but when I plug in the fridge the compressor will not start. I have been told it could be the overload, relay or capacitor. I pulled the capacitor and it looks fine. I attached my resistance meter to it and I saw the electical charge discharging so I think it may be ok. I tested all 3 pins that are attached to the overload and relay or PTC I guess they call it. All seem to have continuity to each other. I located the defrost thermostat behind the back panel wall in the freezer and it is spliced in with protective coating so I'm not sure if I should cut the wire to test continuity on the defrost thermostat or not. What should I do? I see no leaks on the evap coils, condensor coils or any of the other copper piping leading in or out of the compressor so I don't think it's a refrigerant leak of any sort. I'm not sure what the next step is.
    President:
  • GE Master
  • 1,922 Answers
Pull the RTX overload out and shake it, if it rattles chances are good its defective and needs replace
Posted on Dec 25, 2009
My GE fridge GSS25JFMD: freezer seems to be working but the fridge compartment is worm, I don't see any cold air flow from the top. Condesor on thr back is very hot and cooling fan doesn't turn on. I...
The control to the fan comes from the main unit and it runs all the time,. So check out the wiring for the voltage to appear on the fan terminals , there can be break of contact in joints of wire connectors.
Once the fan works the fault must clear off with the cold air blowing.
Sep 19, 2010 | GE Refrigerators
Freezer not worknig.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 05, 2010 | GE GSS25JFM Side by Side Refrigerator
GE side by side refrigrator stop working
If there is nothing operating but the lights you are going to need the board linked below which is for your model.
Main board
May 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side Model GSS25JFMD 2 yrs old. Original problem was not staying cold. now I see if I unplug for half hour it seems to work right but sometimes freezes in fridge . I'm hearing a clicking sound...
These problems are saying relay/capacitor replacement and if that don't work then compressor replacement.
First change the relay and the compresssor cap. See if you have improvement...if not then you will need to have the compressor replaced.
Here is a tip about the relay and cap....
Heatman101
Feb 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Looks like a thermostat problem. The condensor is running but unable to stop when it should. It is the thermostat that should shut it off.
This is a very sophisticated fridge/ freezer and with electronic controls.
There is not much diagnostic you can do yourself other than replacing parts. If you are not comfortable with this type of equipment you should call the professional.
Good Luck.
Feb 27, 2010 | Microwave Ovens
Ge gss25ifrf ww side by side fridge clicking
Sounds like the main control board is bad . Pt # WR55X10656 . This board is located behind the 8 " X 10 " , panel just above the compressor compartment . The compressor relay , is what you hear clicking , cutting the compressor , on/off . Even the dispensor board , is operated by the main control board .
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refrigerator(GSS22ifrf ww) not cooling
Try unplugging it for 30 seconds and then plug it in again. It may reset itself that way.
Jul 29, 2009 | Refrigerators
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Ge Freezer not working
with min. toubleshootin. remove food store else where. Unplug unit. mop up water from ice melting. after 12 hour plug back in. If this work let me know. And I let U know step 2. Good luck.
Oct 12, 2008 | GE GSS25JEMWW Side by Side
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
GE GSS25JFM Side by Side Refrigerator Logo
701 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
