Question about Sony Playstation 3 (PS3) Console
The system powers up but powers down after 2 seconds
  • 129 Answers
Your adapter/power cord maybe going out. try changing it.
Posted on Dec 11, 2009
  • 20 Answers
If you have a multimeter, check the power module and verify that it is producing the listed voltage, if yes, then try to use this module on another appliance in your home. If a "load" fails the device, you have your answer, if not, then you need to looak at having the actual game unit repaired by a qualified person. Most likely, if the unit is out of warranty, you are better off just replacing it. The cost of an actual depot level repair will be excessive.
Posted on Dec 12, 2009
How do I reset a rca tablet
Note: Wipe data will delete all user data.
1. On power off mode, press and hold on VOL+, then press Power button for 3 seconds, and then release both buttons. You will see RCA+Dog opening screen. Waiting for a few seconds, you see the Android laying down on its back.
2. Press VOL+ button once, you see a menu.
3. Volume down to move highlight to "wipe data/factory reset", then press power button to select .
4. Volume up/down to move highlight to "Yes-delete all user data", then press power button to select .
5. When you see "Data wipe complete", press Power button to select "reboot system now", the system will be restarted.
6. Once complete, you will see below initial Welcome screen.
ALL YOU DATA WILL BE GONE.
I hope this helps,
--Robert
Oct 28, 2014 | Tablets & eReaders
I cant get in my phone it says to sign in to google and it will unlock but i dont know my email or password
you may have to hard reset the phone to start the whole system over.
dependoing on what kind of phone you have.
1.) hold the volume down button down.
2.) hold in the power button at the same time
this should take about 30-45 seconds to reset.
if you don't have a power/lock button
1.) hold down the down volume button
2.) hold in the home button.
3.) then hold the power button down
do this all at the same time with all three buttons.
should take about 30-45 seconds to fuly reset
Nov 29, 2013 | Straight Talk ZTE Merit Z990G Prepaid Cell...
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
Mid tablet wont shut down
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Jan 30, 2013 | mid Archos M729B Android Tablet
System runs from about 3 to 15 secs then shuts down. That doesn't give me enough time to do anything in the BIOS setup when pressing F2. Then the system refuses to start (by pressing the power button)...
Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged. The computer should stay on even without an operating system or hard drive installed.
Jun 24, 2011 | Dell Precision Workstation T5400 Quad Core...
When switch on only blank screen
Hi al85009,
Have you tried draining the power of your computer? Often performing power drain resolves any display issue. Please follow the steps below for the basic instructions on how to perform a power drain.
1. Turn off the system completely. You may also press and hold down the power button for 10-15 seconds until system turned off completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the system.
4. Now, press and hold down the power button for 15-20 seconds.
5. Plug in the AC adapter to the power outlet and put back the battery inside the computer. Try turning on the system.
Hope it helps.
Thank you for using FixYa.
Apr 09, 2011 | Dell Inspiron 1525 Laptop
I was working on my laptop - it mysteriously shut down.
remove the battery on the system then unhook the adaptor press and hold the power botton down for 10 seconds this is to power drain *********** board...... then conenct the adaptor without the battery power the system on if it powers on leave it on for a minute or 2 then shut it down again inset the battery turn system back on if it does not turn on with battery something is wrong with the system motherboard conflicting with the battery in it call dell for options if in warranty
Jun 05, 2010 | Dell Inspiron 2200 Notebook
Evaporator coils ice up after a few days and the refrigerator comparment only stops cooling. The unit is 2 years old. When removing the backing from the inside of the fridge and after thawing out the coil...
I have some information on your model and that would involve forced defrost by the service manual page 28 at bottom. How old is your Samsung? Forced Operation Function (Pull-down / Refrigerator Defrost / Refrigerator . Freezer-Defrost / Cancellation)
● This function enables a pull-down mode, a defrost mode for the refrigerator only, a defrost mode for the freezer and the
refrigerator at the same time, and a cancellation of this function.
● Press Power Freeze and Fridge Temp. buttons for 8 seconds simultaneously to get in the ready mode for a forced
operation.
● The display panel will return to normal after 20 seconds in the ready mode.
● At the ready mode, press any button(except Ice Type and Child Lock) once to start a pull-down operation, twice for a
defrost cycle for the refrigerator, three times for a defrost cycle for the freezer and the refrigerator, and finally four times
for cancellation of this function.
● Another way to cancel this function is to simply plug out and in the power cord.
1) Pull-down
1-1) At the ready mode, press any button once then the buzzer will beep (ON for 1/2 second and OFF for 1/2 second)
until this mode is cancelled.
1-2) At this pull-down mode, the compressor will start immediately (No 5 minute delay) and if the system is in the
defrost cycle, it will be cancelled right away.
note) If this pull-down mode begins right after the compressor was off, the compressor may not start to run due to an
overload condition.
1-3) At this mode, the compressor and freezer fan will operate continuously for 24 hours and the refrigerator fan will be
on and off according to the set temperature(34℉)
1-4) After 24 hour operation, the system will be cycled at -14℉ for the freezer and 34℉ for the refrigerator.
1-5) In order to cancel this mode at any time, select the next mode on the ready mode or power off the system.
2) Refrigerator Defrost / Refrigerator . Freezer-Defrost operation
2-1) At the pull-down mode, press any button again on the ready mode to begin the defrost cycle for the refrigerator.
2-2) The beep sound continues for 3 second at the beginning, then ON for 3/4 seconds and OFF for 1/4 second until
this mode cease.
2-3) After this operation, the system will come back to normal operation.
2-4) At this mode, press any button again on the ready mode to operate the defrost cycles for both compartments.
2-5) The beep sound continues for 3 seconds at that time, then ON for 1/4 second and OFF for 3/4 seconds until the
defrost operation cease.
3) Cancellation
3-1) At the R,F-Defrost mode, press ant button again on the ready mode to return to a normal operation.
3-2) Simply unplug the power cord, then plug it again to return to a normal operation.
Press both button for 8seconds at the same time Send maual in one moment, Thanks, Sea Breeze
Jan 20, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Ink system has failed. Unable to copy receive faxes, or print. Error: 0xc18a0201
Try to reset it!
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
I hope this info helps.
Aug 15, 2009 | HP Photosmart C7180 All-In-One InkJet...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
