Question about Kenwood KDC-419 CD Player
Hope can i send an input from I pod or TV into the
How can i send an input from I pod or TV into the stereo? Is there an adaptor i need?
  • mpc1374 Dec 11, 2009
    It appears there is a 13 pin din on the back that they offer adaptors to stereo RCA (CA-C1aux) or to a mini 3.5 headphone (CA-CV2ax) so i should be set thank you.
  • Marvin
    Marvin May 11, 2010
    unless it has a usb port you can't do this.
    Problem Solver:
  • 10 Answers
If you are asking how to send audio from your iPod or TV to a stereo receiver, you will need an adapter for the iPod but may not need one for your TV.
For the TV:
Check the back for two red-and-white round plugs: these are called RCA jacks. Most TVs will have "RCA IN" but fewer will have "RCA OUT (sometimes called MONITOR)." If you do have RCA outputs, simply find an RCA cable (with red-and-white male connectors on each end) that's long enough and connect it to an input on the back of the receiver. It doesn't matter which one.
If you don't have RCA outputs, you MIGHT be able to use a VCR if the VCR has RCA outputs. In that case you would connect your TV cable to the "RF IN" on the VCR. Then plug the yellow (video) RCA connector to the "RCA IN" on your TV, and the red-and-white connectors to your receiver. Then all of your audio would come out of the stereo instead of the TV. This can get complicated, however, because now you will be changing channels either on the cable box or DVR or wherever your TV comes from, or if you don't use a box you will change them on the VCR remote (because the TV will now be on "RCA IN or INPUT 1" at all times). In addition you will control the volume with the stereo remote.
For the iPod:
The best solution is to find a small adapter (I think Griffin makes one) that plugs into your iPod and transmits over a radio frequency you set. So for example, you change the adapter to FM 89.1, and then tune your stereo to 89.1, and as long as the iPod is reasonably close to your radio, the music will play. This is great because not only do you not have to hook up any wires, but it works on ANY radio (alarm clocks, shower radios, and car stereos)! Just be mindful when you purchase the adapter. You do not want to buy a radio transmitter intended for the car, which uses a 12V cigarette lighter plug, and try to use it at home. And if you buy one intended for home, keep in mind it won't let you charge the iPod in the car.
Posted on Dec 11, 2009
SOURCE:
Iwave pod bluetooth speaker
Unless your PC is Bluetooth capable, you'll need to get a Bluetooth device to make it so. This is just one of many such devices to select from. Amazon com Roker Ultra Mini CSR Bluetooth 4 0 Usb Adator for PC and... They vary in size and price. Shop around to find one that best suits your budget. But you want an adaptor/receiver specifically for Bluetooth. (you will need an empty USB port for the adaptor)
Hope this information helps, best of luck!
Feb 06, 2014 | Audio Players & Recorders
I would like to add my i-pod to the receiver so i could listen to the music what kind off cable would i need
An i-pod provides a standard headphone level output. The AVR-1803 has nine RCA stereo inputs that will accept the signal from the i-pod. You need a 3.5mm stereo TRS plug on one end and two RCA plugs on the other end to connect your i-pod to your amplifier. Note: Be careful to select a 3.5 mm plug that has a slim enough plastic moulding to fit into the i-pod headphone output. On your amplifier you simply select the analogue input that you have chosen to use. Be careful of levels when you are setting up. Set the volume of your i-pod to about 50% and set the input sensitivity to zero, press play on your i-pod and gradually increase the gain on your amplifier input. Hope this helps, Don.
Dec 08, 2013 | Denon AVR-1803 Receiver
How can I transfer recordings from S725 to my pc. I have windows XP
You will need to get a 2.5mm mono to 3.5mm stereo adaptor from somebody like Maplin.
The 2.5mm end of this needs to plug into your earphone jack (mono) on your S725.
Get a ready made cable with a 3.5mm stereo plug on both ends.
Put one of these plugs into your 2.5mm mono to 3.5mm stereo adaptor.
Put the other plug of this cable into the AUX input of your PC.
If you do not see an AUX 3.5mm input, look in or around the area where you would normally
plug your headset. Try checking the manual that came with your PC. Some PCs do not have "AUX" marked on the 3.5mm socket.
Be careful not to have the volume level of the S725 too high as you are testing your setup.
You might damage the Mic input of your PC if you blast too high a level at it.
Next you will need some software like Audacity (Free) to record your tapes.
Have fun but be careful if you are not sure about the connections.
Hope this helps.
Sep 12, 2011 | Olympus Pearlcorder S725 Handheld Cassette...
I have a bose radio which is 8 yrs old..what i am trying to do is connect my mini I Pod to my bose...I have audio in and outon back of my bose...I tryed a cable which just has to male ends 91.CM AUDIO...
hi,
You need a STEREO to RCA cable for connecting you I pod to the audio input of you boss. you Can connect the stereo jack in the one end of the cable to the I pod and the RCA end to the boss's audio input L/R.
i have added the picture of the cable for you reference.
ok
Apr 04, 2011 | Bose & Wave& Music System
I have a LG47" tv
Your DVD audio is sent directly to your receiver - not to you TV. That's why you can hear the audio on your stereo. The TV audio is not being sent anywhere - it is "stuck" in the TV and is amplified and sent to the TV speakers. Since the TV speakers are off, you don't hear anything. In order to listen to the TV audio on the stereo system's speakers, you need to send it to the receiver.
You need to have a pair (left + right signals) of audio cables (assuming you wish to listen to stereo sound) from the TV's Audio Output jacks to a pair of Audio Input jacks on the receiver / amplifier. You can use any unused input - CD, Video, Tape, Sat, etc. If you use Tape or Sat audio inputs, when you wish to listen to the TV audio, you must select the Tape or Sat input on the receiver.
Do not send more than one signal to a set of inputs on the receiver. Typically, a CD, DVD and Sat inputs offer two or more of the following types 1) Analog audio. These are the older RCA jacks that have been around since the beginning and require separate cables for left and right channels. 2) Optical inputs. This is the newer digital interface that provides for Dolby Digital (and others) format sound over a single fiber optic cable. 3) Coaxial inputs. This jacks looks like an RCA jack, but usually has an Orange ring - instead of the Red & White rings that analog RCA jacks have. They use a single coaxial cable. 4) HDMI input. This jacks carries both digital video and digital audio signals. If you are using an Optical input for the DVD on the receiver, do not use any other unused analog or digital inputs associated with the DVD to "piggyback" another device like a CD , VHS tape, etc.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 25, 2011 | Audio Players & Recorders
Good morning! I wish to plug our television into the LBT-ZX6 stereo, but the TV's output uses an optical audio cable. Is there an adapter of any sort that could convert the optical cable into the stereo...
You may be able to avoid messing with the optical output completely, if the TV has a headphone output, in which case, a phono-3.5mm jack adaptor will sort you out nicely.
If it has to be optical, I expect you can buy adaptors for this aswell, but I'd expect it to be more expensive.
Most local electronics stores will sell these. Radioshack is a good example. Also, you could look around on the internet.
Jan 25, 2010 | Sony LBT-ZX6 Shelf System
I have my Vizio hooked up to my computer. I have a sub-woofer and speakers. How do I get the speakers to work w/tv mode. They work when I am using computer mode. I have comcast cable and box.
Good day sir, Hi, you see, the TV produces its own sound, you need to feed this sound to your PC. here are options were you need to choose.
  1. You need a separate sub/speaker system for your TV. feed the sub/speaker with the sound line out from the TV. you also need an RCA to stereo baby plug adaptor for your sub/speaker.
  2. If you want to use your PC speakers, feed the line out of the TV sound to the line in of the PC, usually the line in is the blue port, you need an RCA to stereo baby plug. then activate the line in function from the mixer volume properties. This requires that you turn on your PC when in TV mode.
  3. Simply disconnect the sub/speaker baby plud input from the PC and connect it to the line out of your TV using an RCA to baby jack adaptor. (re connect again if you want it on your PC. this is very complicated)
  4. Does your sub has extra input? like aux, or cd, or tuner? feed the TV line out to one of these extra port. use the input selector switch from TV and PC. you need an RCA to stereo baby plug connector.
I forgot to ask, Does your TV has line out? if no, you are stuck with the built-in speakers.
Dec 16, 2009 | Vizio L37 Television
Can i play my ipod thru my tv
You will need to buy a special adaptor which connects from the I-pod to the TV using either component or composite connectors. Check what inputs you on your TV & then any quality audio shop or if there is a specialised Apple shop will supply it.
Nov 28, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Will the Kenwood KDC 1032 RCA outputs work with an ipod adapter similar to an aux output? If so, how?
Hi, if you are trying to get your I-pod to play through your car stereo, then you would need to have the RCA inputs, not outputs. If you connect your i-pod to the stereo outputs it won't work because both things are trying to push sound out of their outputs. If you connect the adapter to the stereo's inputs then it would work.
Aug 11, 2009 | Kenwood KDC-1032 CD Player
Getting stereo speakers to work with flat panel tv
if you hook the low-level audio-out from the tv to an input to the stereo unit, whatever you play on tv will send audio to surround/stereo reciever unit. look on back of tv for red &white AUDIO OUTPUT terminals. plug red/white audio cables from tv to the back of your stereo & plug into audio input of an open source on stereo (tv/video,aux. in,etc.) good luck!
Mar 09, 2009 | Televison & Video
Kenwood KDC-419 CD Player Logo
118 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
