Question about Kodak ESP 5 Printer
My Kodak esp5 says my print head is not connected
  • Trevor Sumnell Dec 13, 2009
    have cleaned the printhead but still same error message. printhead not installed or loose
    yes have contacted kodak
  • 4,472 Answers
This is a fairly common problem. How old is the printer? I would try and contact kodak as most likely they will send you replacement print head at no charge. After you do get a new printhead try and use the printer at least once a week. That is assuming it isn't a more serious problem but I would try that first you can contact kodak at 1800 421 6699
Thank you,
Lee
Posted on Dec 13, 2009
  • 3,230 Answers
Well you need to clean the print head according to the instructions as follows -
Debris may occasionally collect on the print head and scratch the print surface. To clean the print head, you need:
       -Two soft, lint-free cloths.
       -Distilled water and/or isopropyl (rubbing) alcohol.
Dampen a cloth with the distilled water. The cloth should be damp, not dripping.
Wipe the print head Heater Line and Ribbon Guide Bar several times. Always wipe in the same direction to prevent smearing the debris. Use a different portion of the cloth each time.
If debris is still visible, use your fingernail to gently remove it. Do not use a metal object to remove the debris.
Dampen a clean section of the same cloth with water and wipe the print head.
Use the other cloth to remove any excess moisture from the print head:
Lightly dampen the cloth with isopropyl alcohol and wipe the print head as described above.
or
Wipe the print head several times with the dry cloth.
Combination alcohol/water pads (70% alcohol, 30% water) are available from Kodak. To order, call Kodak toll-free at 800-431-7278.
Good Luck!!
Thanks
Posted on Dec 12, 2009
  • 20 Answers
SOURCE: is it possible to print 5x7's with the kodak esp5
Print from your computer :
open the picture you want to print
go to :
File
Print
Properties
another windows will pop up and under general you will see different print size and you can chose there the different paper size and print size.
Posted on Apr 12, 2009
  • 326 Answers
SOURCE: new ink cartridge but not printing green on esp 5 kodak all inone
you need to use the head cleaning tool in the printer properties, youll need to keep running it untill it runs clear and it uses alot of your ink while it does it.
youll find the cleaning option if you go to your
start/settings/printers and faxes, right click on your printer and go to printer preferences then maintinence
Posted on May 08, 2009
Josue Pongco
  • 154 Answers
SOURCE: I need to know what printer head I need for an all
The printhead is replaceable, call kodak and i think they will send you the replacement for free. 1800 421 6699
Posted on Oct 02, 2009
  • 295 Answers
SOURCE: I have a kodak esp5 all in one printer and i am
Kindly go to www.kodak.com/go/printheadsupport and see how to install the printhead properly. Make sure that it snaps in to place properly. If issue persists,call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.Printhead is the part which holds the cartridges and has 4000 nozzles which sucks ink from cartridges.It Might have gone bad.
Posted on Oct 20, 2009
CViveiros
  • 55 Answers
SOURCE: My Kodak ESP5 AiO printer has its print head stuck at its right.
Dear Sir/Ma'am,
• To resolve this issue remove the cartridges and then the printhead (Upon removing the cartridges look into the slot where the black cartridge fitted into. On the vertical wall at the back you will see two small contact points. Place your finger above those points on the black plastic and run your finger towards the top of the printhead. You will feel a little button and by pressing it , it will release the printhead.)
• Remove power
• Please now check for any objects or paper that might be obstructing the movement of the printer carriage - if any are found please remove them
• Wait 5-7 minutes
• Reinsert power
• Reinsert printhead (When inserting the Printhead please ensure that you hear it click into place)
• Then re-insert cartridges, black first then colour.Please also ensure that you hear them clip into place
Regards,
CViveiros
Posted on Oct 26, 2009
Black ink will not print
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
Jun 18, 2012 | Kodak ESP5 AllInOne InkJet Printer
I have a Kodak ESP5 printer . Just put new ink in it and the black is very light. can you explain why?
Sounds like print head is clogged and needs replacing, try the troubleshooting guide on Kodak website, appears to be a common problem with these Kodak printers, if new it should be covered under warrenty although if not they are expensive
Jan 12, 2011 | Kodak ESP 5 Printer
Our kodak ESP5 wont print properly. We have installed new ink (a number of times now) but the ink is still very faded when printed. fed up of having to buy ink and still wont print out dark.
Sounds like print head needs replacing, try the troubleshooting guide on Kodak website to confirm, appears to be a common problem with these Kodak printers, if new it should be covered under warrenty although if not they are expensive
Dec 30, 2010 | Kodak ESP 5 Printer
Used printer only 8 times only for basic print no photo prints changed cartridges 4 times already. first said ink not available, now says print head not connected please re-install.?
Click on this link Kodak Printhead Problems and see the instructions on how to install printhead correctly. If this does not solve the issue, call Kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 01, 2010 | Kodak ESP5 AllInOne InkJet Printer
What does error code 3820 mean for a kodak esp5 all-in-one printer
The error message "Carriage Home detection failed" (error code 3820) can be resolved by following these steps:
To resolve this error:
1.Open the printer access door.
2.Disconnect the power adapter from the printer.
3.Gently hold both sides of the carriage, located immediately behind the print-head, and make sure the carriage moves freely.
•If the carriage does not move freely, contact Kodak.
4.Remove the print-head and ink cartridges.
5.Reinstall the print-head and ink cartridges, making sure each clicks into place.
6.Connect the power adapter to the printer.
7.Turn the printer on, if necessary.
8.Close the printer access door.
If the error continues, contact Kodak.
Sep 07, 2010 | Kodak Office Equipment & Supplies
My Kodak esp5 says my print head is not connected. I am using Kodak ink. Can you help please
Try installing the printhead 2-3 times. If still get the same error message. call Kodak tech support, printhead will be replaced free of charge
Dec 02, 2009 | Kodak ESP 5 Printer
Kodak ESP5, duplex, only prints first side
You can try ressting the settingson the printer By going to Menu -> Printer settings -> Reset All settings and hit Ok.
If the issue persists, try upgrading the printer software and the firmware. The link for the upgrade is kodak.com/go/esp5downloads
Oct 07, 2009 | Office Equipment & Supplies
I have a kodak esp5 all in one printer and i am getting a print head error. i took the print head out a few times and reinstalled it.i have new carttriges and am still getting the same print head errors.
Aug 29, 2009 | Kodak ESP 5 Printer
New ink cartridge but not printing green on esp 5 kodak all inone
May 08, 2009 | Kodak ESP 5 Printer
Is it possible to print 5x7's with the kodak esp5
go to :
File
Print
Properties
Apr 11, 2009 | Kodak ESP 5 Printer
Kodak ESP 5 Printer Logo
41 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
