1999 Ford Taurus Logo
Posted on Dec 11, 2009
Change radiater and heater radiater i dont have taurus 98
Chang e radiater and heater radiater i dont have heat in the car
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 26, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
163
Points
Have your heater core flushed. Works like a charm every winter when I do it.
1997 ford Taurus 3.0 6cyl. Has not heat
Empty cooling system and reverse flush the heater core with water hose till water comes out clear. Then reverse procedure till water is clear. Fill system with water and turn car on, while car is running open drain plug and continue to keep radiator full while draining it at the same time turn on your heater with heat on high and blower on high When water is clear flush system and wait for engine to cool down. Refill with antifreeze and turn engine on, check for leaks and to see if you have heat. If still no heat change heat core.Let me know how you make out.
2000 ford taurus heater not working. What can be wrong?
It sounds very much like the heater control door (inside the heater box) is sticking in one position or the other. It's intended to direct air through either the AC's evaporator or the heater core, depending upon whether you want heat or cooling.
Assuming (highly likely) that the control door is vacuum-operated, you may have a vacuum leak anywhere from the engine to the heater box inside the passenger compartment, via the heater control unit.
Heater does not work on 1999 ford taurus
heater motor? and/or no heat inside of car?...
I have a 2002 ford taurus and the heater isnt working all that well and i was wondering what things i should check
The heater core is under the dash.
If the engine is reaching normal temp, and both heater hoses are hot, you may have a problem with a blend door under the dash.
I have a 2000 Ford Taurus my blower is blowing fine the heat is coming out cold i have recently changed my theromastat and the heat is still blowing cold
The heater core (a mini radiator located under the dash) or its feeder hoses are clogged. They are not allowing water to circulate through the heater core. That is where the heat comes from.
No heat-changed heater core, changed water pump, flushed cooling system. car does not overheat, but blows no heat. what might be the problem?
If you have changed you said the olny thing left would be thr thromostat is not opening for some reason Then no heat would get from the engine back to the radiator But im supprised that your not having a over heating problem What dose the engine temp gauge read when the engine hot and idiling
I BLEW a heater hose in my 1998 ford taurus .. just want to know how hard is it to change and if i should flush the radiator after?
only reason a heater hose will blow off is it was on loose or you were over heating. Do not do a coolant flush until after you determine its ok now,
How do I change a thermostat in 2003 taurus?
The thermostat is located in a housing on your engine that the top radiator hose connects to... but it isn't tied to your heater problem. The thermostat restricts coolant flow until the engine warms up, but doesn't control the car heater.
You may have a fuse issue if the fan isn't blowing any air. That's an easy check and fix. Autozone might check it for you.
I hope this helps... Good luck.
2answers
99 Taurus heater not working.
sounds like you may have an air bubble trapped. Try loosening the radiator cap & running the engine at 1500 rpms till the thermstat opens & see if you can "burp" the air out. You may lose a little coolant this way. shut off car & recheck coolant in radiator and reservoir bottle. Just because reservoir is full, doesn't mean radiator is full.
1999 ford taurus
it could be but if i where you i would check all the fuses
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
