Question about Amana Dryers
Timer doesn't work in less dry mode - Amana Dryers
  • 6,784 Answers
Hi. This will be the result of a failed timer motor, or the dial cogs could be worn in the less dry section of the timer dial plate. Generally, this will require you to replace the damaged component. This will be the timer module, itself. It is damaged.
Replacing the timer control module, will correct this issue.
Posted on Dec 11, 2009
SOURCE:
Dryer Timer doesn't move in Easy Care Mode
do you have heat?does it stay hot while in coll down?if so your heating element is grounded,open the door,look up and remove the two screws holding the top panel in place,pick top panel up just a little and move it to the left that should remove the top panel, put it on cool down or no heat and run it,if the heat stays on this is your problem the element is sagging and touching the metal cover around the element,the way the timer works is on timed dry it counts down like a clock until it turns off when on more or less or auto same thing the dryer starts,the heat comes on and when it hits temp. the heat shuts off when the heat is off the timer will advance to off when the heat starts again the timer stops,if the element isn't grounded then you still could have a bad element there are two elements in your dryer if one is broke the timer won't advance or some have only one element so if the timer doesn't advance you probably have no heat or a bad cycling thermostat or a bad sensor up front where the lint filter is.you'll have to check them with a meter.first thing to check is the heater located behind the drum.
Jan 15, 2018 | GE Dryers
My dryer works on high heat on the timed side of the knob, but won't work on the low heat and high heat (more dry, less dry or energy preferred setting)
Does this mean the timer wont move or it will not dry ? if it will not dry it is more than likely the timer , if it wont advance then you have a shorted element
Nov 03, 2015 | Dryers
My kenmore elite #110.73012181 electric dryer with autonsense feature no longer sensing, keeps on drying for hours after clothes dry when on less dry mode or normal dry mode
The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
Jan 02, 2014 | Kenmore Dryers
Whirlpool LER4634EQ1 works fine on the less dry, more dry settings, but will not work on the timed heat setting. Do we need a new timer mechanism or cycling thermostat?
Timer. Probably because that cycle is used the most; and over time the contact inside that timer gets burned up:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 25, 2011 | Whirlpool LER4634J Electric Dryer
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
No heat after first cycle
This condition is normally caused by a faulty cycling thermostat. Movement of the timer in the auto-dry mode is controlled by the cycling thermostat. Movement of the the timer in the time-dry mode is not controlled by the cycling thermostat, but by the timer motor.
Below is a link directing you to an enlarged image of the thermostat. You will also find other pages within the website with exploded view diagrams and disassembly procedures, prices and shipping information.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=601359&PPStack=1
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 18, 2008 | Amana ALG331RAW Gas Dryer
Timer does not advance and dryer seems to get extremely hot. Ireplaced the timer mechanismbut I still have the problem.
This may not be the solution to your exact problem but for those looking for why there timer will not advance and why it keeps running even when the items are dry: The usual problem is not the timer but the mosture sensor (if your dryer has one).
1: Check the mosture sensor light/indicator. If is still shows some mosture or flashes even when the items are dry, you have a mosture sensor problem, probably not a timer issue - luck you.
2: Check if the timer will advance and the dryer will turn off when you have it in the TIMED mode (i.e. 10mins - NOT the more/less dry modes.) If so, then it is indeed a sensor problem.
2: Check that the wires to the mosture sensor have not fallen off (as in my case - a simple repair). The senor is usually two metal bars somewhere near the front part of the inside of your dryer. You may have to take off the door and the front pannel (be sure to unplug the dryer first) to get at the two wires to clip on to the sensor. Clean any lint and make sure they are conneted. If well connected then replace the sensor ($15-$20 and very easy to do).
Sep 15, 2007 | Maytag Atlantis MDE7657BY Electric Dryer
Dryers Logo
77 people viewed this question
Top Amana Dryers Experts
Sal De
Marvin
Marvin
Android Man
Android Man
Are you an Amana Dryer Expert? Answer questions, earn points and help others
