Question about Dell Dimension 4600 PC Desktop
My pc will not boot up it says windows/system32/ is missing
  • 1 more comment
  • bilyn1936 Dec 11, 2009
    have the disc.used it to reinstall windows worked fore a day than would not boot up again
  • NOT ME May 11, 2010
    Is that exactly what it says? Please quote the message exactly as you see it.
  • larry_d44ca May 11, 2010
    Do you have your original Windows disc that came with your system or with the current installed edition of Windows?
    Problem Solver:
  • 14 Answers
It sounds like the installation of Windows is corrupt, but the hard drive is still likely to be OK. You will need to boot off the Windows Operating system CD/DVD and perform a REPAIR of the Windows Operating System. If a repair fails then a fresh installation of Windows should still be possible, but you will then also need to re-install any applications too. Provided you do not re-format the hard disk, all of your documents and settings should still be accessible.
Posted on Dec 11, 2009
    Scholar:
  • 47 Answers
There is a corrupt operating system file - you will probably need to load the recovery disk (typically supplied with ever dell OEM system), and do a recovery load. Go through the process of installing the OS, but when you get to the part where it asks what you're doing, do the "R" install (for "Repair"), it should load the correct file, and you're on your way
  • 4,281 Answers
For that you need recovery disk.
Put that disk in cd/dvd rom.
Then when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot option then set first boot device as your cd/dvd rom then save settings and exit.
Then it boot with that recovery disk then follow the procedure and choose "R" for recovery console then type in prompt "chkdsk /r"
then press "y
then it fix error on harddisk.
Then resatrt computer then if still same error then again boot computer with disk then choose "r" for repair previous windows then it repairs it.
Let me know if you need further assistance.
Thanks for using FixYa.
3 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: Problem booting up dell dimension 2300 desktop.
You have no choice either you should reinstall your system, you should provide windows CD/DVD installation and boot your system using this disk.
However; you should backup your important files be cause most likely the all files will be removed during the installation process.
Posted on Jan 04, 2008
  • 12 Answers
SOURCE: following files missing or corrupt: \windows\system32\config\system
Well this means one of important files needed to start Windows is corrupted (it's a registry file).
I'd recommend repairing Windows installation. If you have Windows XP and also the Original Windows CD follow: this guide.
Posted on Dec 31, 2011
Hp compaq 530usdt windows\system32\conf\system. File missing or corrupt
insert original win installation cd and reboot... when in boot mode make sure you are booting from CD, not from disk, when message asking that you "boot up from cd " appears, just press any key, and folow procedure, but do not install a new copy of windows ! There must be "repair your computer" option on your CD, for Win Xp - it is "recovery console" ! When repairing finishes restart computer and boot from disk (just do not press anything when you see message "boot from CD..." and let windows from HDD configure it self).
Mar 10, 2014 | Computers & Internet
Tip
How To Fixed Corrupted or Missing \WINDOWS\SYSTEM32\CONFIG
If you get the error:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
  1. Insert and boot from your WindowsXP CD.
  2. At the first R=Repair option, press the R key
  3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
    Typically this will be #1
  4. Enter in the administrator password when requested
  5. cd \windows\system32\config
  6. Depending on which section was corrupted:
    ren software software.bad or ren system system.bad
  7. Depending on which section was corrupted
    copy \windows\repair\system
    copy \windows\repair\software
  8. Take out the CD ROM and type exit
on Sep 20, 2010 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
System32 file missing or corrupt
You may find some help on YouTube. Open the link below and check out the thumbnails on the right for further help
PC Repair File missing or corrupt windows system32 config system
Oct 10, 2017 | ASUS Eee PC 1001PX (1001PXEU17BK) Netbook
On start up <windows root>/system32\hal.dll.
Your Hall.dll is fine but you have to repair it.
ATTRIB C:\BOOT.INI -a -h -r -s
DEL C:\BOOT.INI
BOOTCFG /rebuild
FIXBOOT
Jan 17, 2011 | Acer Aspire One PC Notebook
Windows\system32\ntoskrnl.exe filie is missing or corrupt.
need to reinstall windows cause the system files for the operating system is corrupt.
On your compaq, keep pressing F10 as you turn on the computer and that should take you into the factory restore.
If you can't get into that then you'll need an operating system cd and then download the drivers off of the compaq website: partsurfer.hp.com
Jan 11, 2010 | HP Compaq Presario SR2020NX PC Desktop
C:\windows\system32\hauurjab.dll is missing on my
Just google the error msg and you'll find the solution for it. At most times, ppl recommend you to delete this particular registry file that is associated with this dll file. But if I were you, i would better reinstall the operating system. Just google the error and give a try. Best o'luck.
Hope this helps, If so, rate me.. ,thanks - billa
Sep 05, 2009 | Microsoft Windows XP Home Edition
\windows\system32\config\system missing or corrupt
You can do a refresh of your Windows OS, if you have Windows XP. You need to boot to your XP CD and do a repair. This will only restore the Windows OS files and you will not lose your personal data.
This should help. please rate my response.
Feb 17, 2009 | Gateway MX6440 Notebook
Windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
Type bootcfg /list to show the current entries in the BOOT.INI file
Type bootcfg /rebuild to repair it
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
Medion
I am assuming you are having a problem with a missing or corrupted system32\hal.dll under Windows XP. There are a few steps you can take to try solving the problem.
First, try rebooting. Sometimes the problem seems to go away on its own.
If that doesn't work, boot into "safe mode with command prompt" and type c:\windows\system32\restore\rstrui.exe
If the problem still persists, your best bet is to boot from your Windows XP disc and perform a recovery installation of Windows, which should clear up the problem.
Jan 14, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
65 people viewed this question
Alun Cox
